5-axis Machining Centers
VTC
Traveling column vertical machining center for 5-axis machining
  • Machining of complex workpiece contours by simultaneous 5-axis machining*1
  • Machining at any angle of vertical, horizontal, and slanted surfaces with ±110° B-axis swiveling head, increasing productivity through process integration.
  • 137.8″ × 32.28″ long table allows machining of long workpieces, multiple pieces, and can be used as a 2-pallet changer.*2
  • 18000 rpm high output spindle for machining a variety of materials from aluminum to steel
*1: VTC-800/30SR requires an optional NC rotary table.
*2: Optional fixed table for VTC-800/30SDR has different dimensions.
Full view of VTC-800/30
Swivel axis enables various machining
The b-axis swiveling head with a swivel range of 220° performs indexing at 0.0001° increments with a zero-backlash roller gear cam and servo motor.
Index coupling can be clamped every 5° increments and is suitable for heavy-duty cutting.
In addition, any angle of vertical, horizontal, and slanted surfaces can be machined, improving productivity through process integration.
VTC-800/30B axis swiveling head
High-performance spindle for a variety of production requirements
The VTC-800/30 series has a 18000 rpm, 35 kW (47 HP) [50% ED] high output spindle.
The spindle can be used to cut various materials, including aluminum, cast iron, and steel.
VTC-800/30 spindle
Flexible working area for a wide range of machining
The 118.1″ X-axis stroke and the 31.5″ Y-axis stroke are suitable for a variety of machining.
VTC-800/30 full view machining scene
High speed operation
The advanced control system, servo motors, and roller guides maximize the capacity of the high-performance spindle and achieve the fastest rapid traverse rates, and feedrates, in its class. This reduces non-cutting time.
Rapid traverse rate (X-, Y-, Z-axis) 1968.5 IPM
NC rotary table (option)*
Selecting the optional NC rotary table enables simultaneous 5-axis machining.
The rotary table, which can be placed horizontally or vertically, can also be placed on either side of the machine table.
The same roller gear cam as the B-axis allows contour machining.
*Compatible with VTC-800/30SR only
VTC-800/30 rotary table Horizontal NC rotary table
VTC-800/30 rotary table Vertical NC rotary table
Removable center partition (option)*
By dividing the machining area with an optional center partition, one side can be machining while the other side is installing next workpiece, thereby increasing productivity.
Mounting the optional NC rotary table on both sides enables much higher-value machining.
* Compatible with VTC-800/30SR only
VTC-800/30 removable center partition
Dual synchronized rotary tables*
Ideal for machining long 5-axis workpieces such as air craft parts
The VTC-800/30SDR has a dual synchronized rotary tables and, by eliminating the fixed table, a highly effective chip disposal.
This is an ideal solution for machining aerospace components which require high-accuracy simultaneous 5-axis machining and high material removal rates.
*Compatible with VTC-800/30SDR only
VTC-800/30 dual synchronized rotary tables
Applications
1: Tail Rib 2: Floor beam 3: Fuselage rib 4: Wing Rib 5: Stringer
temp
Ergonomic design for convenient operation
Excellent table access
The door is sashless, without any beams in the ceiling area. There is no interference when using an overhead crane for fixture setup and loading/unloading of large workpieces.
Large windows
The large front door windows as standard allow the operator to easily monitor the machining process.
VTC-800/30 large window
Accessibility
The operator door provides excellent accessibility to the table, making setup easier.
VTC-800/30 Accessibility
VTC
VTC-800/30SR
Table size137.8in x 32.3in
Tool shank (standard)CAT40
Max. spindle speed18,000 rpm
Max. workpiece size193in x 32in x 33.9in
VTC-800/30HD
Tool shank (standard)CAT50
Max. spindle speed10,000 rpm
Max. workpiece size193in x 32.3in x 33.9in
VTC-800/30SD
Table sizeΦ19.69″
Tool shank (standard)CAT No.40
Max. spindle speed18000 min-1 (rpm)
Max. workpiece sizeΦ32.28″ × 145.28″
Reference Videos
