5-Axis Machining Centers
VC-Ez X
Designed and built in Kentucky, VC-Ez X Series machines are optimized for simple operation as well as fast and easy installation, offer enhanced ergonomics, stable and reliable part processing, and long-term reliability.
  • Hybrid MX Roller Guideway Systems on all linear axes
  • Pre-tensioned ballscrew system with support at both ends
  • Thermal Shield technology ensures continuously stables machine
  • Roller gear trunnion and rotary table for fast, accurate, 5-axis machining
Spindle
  • Precision-balanced spindle cartridges
  • Thermally controlled spindle minimizes growth and contraction for stable machining
  • Large headstock castings eliminate torsional displacement when heavy side-load milling
Structure
  • Base, column, saddle, and headstock castings are all designed with high-speed and high-torque cutting applications in mind
  • Castings and ambient thermal conditions are monitored to make axis adjustments for part-to-part consistency
MX Hybrid Roller Guide System
  • More surface contact for greater load capacities
  • Higher positioning accuracy than boxways
  • Faster and greener than boxways with nearly twice the rapid traverse rate and less contamination in machine coolant system
Thermal Displacement Control
In addition to environmental changes such as increases or decreases in room temperature, operations such as spindle start/stop create sudden expansions and contractions in the spindle. Being able to monitor and react to thermal disruption provides stable machining accuracy that can be maintained over long periods of time.
High-Speed ATC
Our high-speed ATC system utilizes a reliable servo-driven cam actuation system that aids in rapid tool change and reduces noncut cycle time. Spindle utilization is also increased through bidirectional rotation of the magazine to the next required tool position, adding productivity to your facility.
Tool Changers
High-capacity CAT 40 tool magazines, common throughout the Ez Series, minimize setups for a variety of workpieces while ensuring adequate tooling for uninterrupted operation.
Standard: 30 tool
Optional: 50 tool
Ease of Use
Easy tool loading/unloading
Wide door opening
Ease of maintenance and safety
Easy tool magazine access
MAZATROL SmoothEz5 Adjustable operator panel
MAZATROL SmoothEz5 Control
15" touchscreen coupled with a dual core, 800 MHz processor which provides unparalled power and ease of use.
  • Five informative process home screens
  • High performance chip converyor interface
  • SMS (SMOOTH machining configuration)
  • MAZATROL Conversational Programming
  • QUICK MAZATROL
  • Intelligent Pocket Milling
  • EIA (G-Code)
Optional Accessories
Ez Tool Station
Programmable Coolant
Three-Color Status Light
Telescopic Air Nozzle
Workpiece Touch Probing
Automatic Tool Setter
Mist Collector
Chip Conveyor
Flood coolant
Through-spindle coolant
Mazak SUPERFLOW (1,000 psi)
Cover coolant inlcuding handheld coolant nozzle
Automation
Custom Solutions
COBOT
Mill Assist
VC-Ez X
VC-Ez 16X
Table size15.75"
Tool shank (standard)CAT No. 40
VC-Ez 20X
Table Size19.69"
Tool shankCAT No.40
Reference Videos
