| Pallet size | Φ23.62″ × 19.69″ |
| Tool shank (standard) | BIG-PLUS No.40 |
| Max. workpiece size | Φ28.74″ × 17.72″ |
5-Axis Machining Centers
VARIAXIS C
- A wide range of spindles meet various machining requirements, including high-speed machining of aluminum and machining of difficult-to-machine materials such as stainless steel, nickel, and titanium
- Wide variety of automation equipment, including a 2-pallet changer, robot, and hydraulic/pneumatic fixtures
Long stroke for multi-surface and 5-axis machining
A wide stroke range of the X- and Z-axis allows the tool to approach the tip and lower part of the workpiece in multi-surface and 5-axis machining, where the B-axis is tilted significantly. It ensures vibration-free machining with short tool projection.
The high feed rates significantly reduce non-cutting time in simultaneous 5-axis machining, achieving high productivity.
Selectable spindle for machining workpieces
Variety of spindle selections for matching material properties
We offer a lineup of high rigidity and high-speed spindle that can perform heavy-duty machining of steel as well as high-speed machining of non-ferrous materials such as aluminum. You can select the optimal spindle to suit your workpiece.
| Standard | High-torque* | High-speed* | ||
| Spindle speed | 12000 rpm | 15000 rpm | 18000 rpm | 20000 rpm |
| Output (40% ED) | 11 kW (15 HP) | 46 kW (62 HP) | 30 kW (40 HP) | 42 kW (56 HP) |
| Torque (40% ED) | 52 ft・lbs | 148 ft・lbs | 77 ft・lbs | 119 ft・lbs |
| Tool shank | BIG-PLUS No.40, CAT No.40*, HSK-A63* | |||
- * Option
Machining example (test results)
15000 rpm high-torque spindle
Φ3.15″ face mill (6 teeth)
Speed: 995 rpm
Feedrate: 61 IPM
Depth of cut: 0.23″
Material: S45C
Material removal rate: 581 cm³/min
High rigidity table
The tilting rotary table is supported at two ends. High-speed, high-precision, and high-rigidity machining is achieved by utilizing roller gear cams in the B-axis and C-axis to eliminate backlash.
| Model | VARIAXIS C-600 | VARIAXIS C-700 |
| Max. workpiece diameter | Φ28.74" | Φ33.46" |
| Max. workpiece height | 17.71" | 19.69" |
| Max. workpiece weight | 1102 lb | 1543 lb |
| C-chamfer | C110 mm | C90 mm |
VARIAXIS C-600 1: H450 mm 2: Φ730 mm 3: C110 mm
VARIAXIS C-700 1: H500 mm 2: Φ850 mm 3: C90 mm
High rigidity structure and MAZATROL SmoothAi for high-accuracy machining
High accuracy 5-axis calibration MAZA-CHECK
Position misalignment and incline of the rotary axes can automatically be measured and compensated to realize high accuracy 5-axis machining.
The centers and tilts of rotary axes can be automatically measured and compensated as well as linear axes.
- * Wireless touch probe RMP600 is an optional equipment.
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. It stabilizes continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors. New algorithms have improved the accuracy of compensation. Furthermore, by accumulating and learning data from subsequent measurements, thermal displacement compensation can be optimized for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Smooth Ai spindle*
* Option
2-pallet changer*
The optional 2-pallet changer allows you to load materials for the next processing step or setup during machining, improving productivity.
| VARIAXIS C-600 | VARIAXIS C-700 | |
| Pallet size | □ 19.69" | □ 19.69" |
| Max. workpiece size | Φ28.74" × 17.72" | Φ28.74" × 19.69" |
| Max. loading weight | 1102 lb | 1323 lb |
* Option
Expandable multi-pallet changer system*
By setting up materials to multiple pallets, the machine can run unmanned for longer periods of time, thus increasing machine availability.
The pallet size, maximum workpiece size, and load are the same as those of the 2-pallet changer specification.
*Optionally available on VARIAXIS C-700
- 2PC
- 4PC, 6PC
MPP (MULTI PALLET POOL)
MPP (MULTI PALLET POOL) is a space-saving multi-stage pallet stocker system developed in response to the growing demand for automation. This automation system is ideal for small-lot, multi-product production and will dramatically improve productivity. The MPP is designed to be attached to the side of the machine, allowing access to the workpiece from two locations: the operator's door and the loading station.
Flexible pallet stocker capacity
6, 12 and 18 pallet storage capacities are available after initial installation.
- 1. 6PC: 3 pallets × 2 levels
- 2. 12PC: 6 pallets × 2 levels
- 3. 18PC: 6 pallets × 3 levels
MAZATROL SmoothAi drives innovation for even higher productivity
SMC PLUS
The cutting point of the EIA program are compared with the 3D model, and the command points are automatically corrected to reduce cutting residue and generate a smooth path trajectory, resulting in high-quality machining.
Digital Twin software for high productivity*
Digital twins recreate real-world factory environments in cyberspace, bringing about innovation in production. By utilizing digital twin software that is compatible with MAZATROL SmoothAi and leverages IoT technology, the machines in the factory can be virtually replicated, leading to significant efficiency improvements in the production process. It provides your office PC with the same environment as the actual MAZATROL SmoothAi. Virtual machine construction enables programming, editing, simulation, and analysis for multiple machines. The setting data of the actual machine is synchronized, which ensures the accuracy of the digital setup.
* Option
