Chuck size | From 18" |
Max. machining diameter | Φ35.83" |
Max. machining length | 41.22" / 80.31" / 125" / 160" |
CNC Turning Centers
SLANT TURN
- Powerful cutting of large-diameter workpieces with high torque spindles
- Machine construction with high rigidity roller guides
- Wide range of spindle bores up to Φ14.76″
Max. machining diameter Φ 35.83"
Max. machining length 40" to 161.38"
Spindle bore variations
Φ 7.28"
SLANT TURN
500, 500M
Φ 10.83"
SLANT TURN
550, 550M
Φ 12.6"
SLANT TURN
550, 550M
Option
Φ 14.76"
SLANT TURN
600, 600M
High torque for powerful cutting of large-diameter workpieces
Achieves high-efficiency machining with full power even in low-speed ranges
Max. torque | 5163 ft・lbs |
Main spindle power | 45 kW(60 HP) |
High-power milling spindle that rival those of small machining centers
SLANT TURN 500M, 550M, and 600M are capable of highly efficient milling/turning. A high-torque version is also optionally available.
Automatic steady rest with significantly reduced travel time
The maximum available steady rest size is Φ16.14" - largest for this turning center class. Positioning time is considerably reduced with operation by CNC. The tailstock can approach much closer to the steady rest for an expanded machining area.
Tailstock to handle both long and short shaft workpieces
The tailstock quill can extend 9.84" making it possible to support both long and short shaft workpieces.
This eliminates the need to remove the steady rest when changing the workpiece from long to short shaft.
