CNC Turning Centers
QT-Ez
Designed and built in Florence KY the QT-Ez Series brings everything you expect from Mazak at an attractive value.
With integrated spindle designs along with high-rigidity machine structures, QT-Ez Series machines give customers high levels of performance and value. From turning to milling, Y-axis and 2nd spindle designs, our QT-Ez Series is as diverse as your needs. A wide lineup of chuck sizes allow part processing for various industries.
Machine Structure
High-rigidity constructions
Built-in motor spindle
Roller guides on all linear axis
0.0001° C-axis indexing angle
Thermal displacement control function
High-performance Spindles
Air and liquid cooled integral motor headstocks on QT-Ez machines allow users to gain high productivity and reliability.
Milling Turret Configurations
Bolt-on Turret: The Bolt-on turret block is mounted to a roller gear cam direct index system. The use of rotarytools allows shops to realize the productivity of true Multi-tasking. The Mazak Bolt-on turret makes part changeover fast and repeatable, improving overall efficiency.
BMT 55 Turret: The 12-position BMT turret is designed for tooling interchangeability. The use of a non-lift roller gear cam design improves performance for non-cutting processes. Utilizing random selection/shortest path indexing, chip-to-chip time when changing tools is optimized.
Productivity Enhancements
Mill Drive
Mill Holder II (Bolt-on only)
Position/hydraulic quill tailstock
Servo-driven programmable CNC tailstock
Full contouring second spindle for DONE IN ONE®
part processing (MSY)
Y-Axis (MY, MSY)
Automation
COBOT
Bar Feeder
Auto parts catcher
Workpiece Conveyor
Ergonomics and maintainability
Operator Door
Large window
Ergonomically placed spindles
Centralized maintenance
Color-coded cabling
Ez Operation
15-inch touch screen for intuitive operation
Screen is designed for ease of use and display can be customized.
Ez Machining
Equipped with heat displacement compensation system "Thermal Shield"
SMC (SMOOTH MACHINING CONFIGURATION) can adjust machining features according to the processing shape and method.
Ez Setup
Flexible layout
You can customize the layout of the CNC screen, including the displayed data, menus, and on-screen keyboard.
Moving the keyboard to a position that suits the height reduces the load on the operator.
Customizable display
You can display any combination of information. By customizing the combination according to the work process, you can check the data and work with a minimum of screen transitions.
Programming
MAZATROL interactive programming with
Re-threading function
Override variable threading function
VCF function
Mazak MT Tablet
Smooth CAM AI
Optional Accessories
Automation support
  • Automatic tool eye
  • High/low chuck pressure switching
  • Automatic door
  • Extra work light
  • 3-color signal tower
Chip Disposal
  • Chip conveyor
  • Air hose prep
Coolant
  • Coolant system
  • Additional head-side coolant nozzle
  • Mist collector
  • Mazak SUPERFLOW 1000 psi
    high-pressure coolant systems
  • Coolant temparature control
  • Coolant gun
Reference Videos
Chuck size: 8-inch
QT-Ez 8
Chuck size8"
Max. Machining DiameterΦ16.13″
Max. Machining Length23.47″
QT-Ez 8M
Chuck size8"
Max. Machining DiameterΦ13.5″
Max. Machining Length20.63″
QT-Ez 8MY
Chuck size8"
Max. machining diameterΦ13.5″
Max. machining length22.4″
QT-Ez 8MSY
Chuck size8"
Chuck size: 10-inch
QT-Ez 10
Chuck size10"
Max. machining diameterΦ16.13″
Max. machining length22.83″
QT-Ez 10M
Chuck size10″
20.2″
QT-Ez 10MY
Chuck size10"
Max. machining length20.2″
QT-Ez 10MSY
Chuck size10"
Max. machining length21.85″
Chuck size: 12-inch
QT-Ez 12
Chuck size12"
Max. machining length21.47″
QT-Ez 12M
Chuck size12"
Max. machining length18.94″
QT-Ez 12MY
Chuck size12"
QT-Ez 12MSY
Chuck size12"
21.22″
Inquiries about our products
