Chuck size | 6″ |
Max. machining diameter | Φ23.62″ |
Max. machining length | 23.23″ |
Y-axis travel | 8.27″ |
INTEGREX i-H
- The flat design of the machine body front greatly improves accessibility and linkage with automation systems such as articulated robots and stockers.
- Power increased spindle and high rigidity machine structure.
- Long Y-axis stroke for expanded machining capability
Enhanced machine design to easily incorporate automation
Flat design of the machine body front for easy adaptation to automation
The standard compact milling spindle is 17% shorter in overall length than the conventional milling spindle, increasing the machining area with minimum interference. X-axis and Y-axis strokes are expanded to secure large machining areas.
Based on structural analysis, the best machine structure combining turning centers and machining centers are designed to achieve stable, high-accuracy machining over the long term. High-accuracy machining is achieved over the entire Y-axis stroke.
- 1: |16.93"
- 2: |Y-axis 11.81" (i-250H, i-350H, i-450H series)
Y-axis 8.27" (i-100H, i-200H series) - 3: |X-axis 27.36" (i-250H, i-350H, i-450H series)
X-axis 21.06" (i-100H, i-200H series)
Based on the spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. Stabilizes continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors. Furthermore, by accumulating and learning data from subsequent measurements, thermal displacement compensation can be optimized for each machining environment to stabilize machining accuracy.
- Machining
- Workpiece inspection
- Simulation
Heat displacement control
- Spindle temperature control
Thermal displacement of the spindle is suppressed to improve machining accuracy. - X-, Y-, Z-axis ball screw core cooling (Standard Specification)
Temperature-controlled cooling oil is passed through the inside of the ball screw to suppress heat generation and prevent loss of machining accuracy.
Automated systems for a variety of products and production volumes
Bar feeder*
Bar feeder can be installed to supply bar materials. The optional bar feeder scheduling function supports high-mix, low-volume production and set production.
* option
Ez LOADER*
Ez LOADER is a space-saving automation solution using a collaborative robot. It offers automatic operation without the need for extensive teaching, and customers can also customize their own operation patterns.
* option
Mazak AUTO FLEX CELL*
A self-run type articulated robot and stockers are compactly arranged in the front face of the machine to automate various setup operations such as workpiece loading/unloading, chuck jaw supply, and special tool exchanging.
* option
Auto Jaw Changer*
With auto jaw changer, 10 sets of chuck jaws can be automatically replaced for each of the main and second spindles.
* option
CNC system
MAZATROL SmoothAi provides unsurpassed productivity through even faster and higher precision control while elevating your production with AI and digital twin technology.
