Tool shank | CAT No.50 / CAPT C6 |
Max. workpiece size | Φ49.21″ × 49.21″ |
INTEGREX e-RAMTEC
- Long X-axis and Y-axis strokes for high-accuracy machining of large parts
- Ram spindle for deep inner diameter boring and milling
High-accuracy machining with double column construction
Double-column construction suitable for top-face machining of large parts
By taking advantage of the double-column construction and the long X-axis stroke beyond the milling spindle, top-face milling can be performed with only linear X- and Y-axis positioning, resulting in stable machining accuracy and higher productivity.
X-axis stroke
Ram spindle mounted on 5-axis controlled vertical multi-tasking machines
Ram spindle
The ram spindle with a vertical stroke of 35.43", mounted next to the milling spindle, performs deep inner diameter turning and milling that cannot be machined even with long tools, thus achieving further process integration.
Automatic ram spindle tool changer
A dedicated tool magazine is prepared to hold 40 turning and milling tools. The machine can handle a wide variety of machining and change to spare tools during long-term machining.
Milling spindle
Built-in motor milling spindle is both compact and high power. In addition to the 10,000 rpm standard spindle for various materials, the lineup includes a 5,000 rpm optional spindle suitable for high-torque machining of difficult-to-machine materials and a 15,000 rpm optional spindle that enables high-speed machining.
*Option
The B-axis (travel: 150°) is indexed and positioned with high precision over the long term using a roller gear cam which eliminates backlash.
Turning spindle
The high-power, high-torque turning spindle performs efficient rough machining and finishing of large-diameter, heavy-duty workpieces. In addition, the C-axis can be positioned in 0.0001° increments to ensure high-accuracy machining.
Higher productivity in multi-product machining
2-pallet changer for efficient setup
2-pallet changers promptly replace pallets loaded with heavy workpieces, and the setup station rotates with high precision. In addition, the optional workpiece centering tool supports the operator to smoothly perform the alignment work required for turning.
*Option
TOOL HIVE*
TOOL HIVE is a rack-type magazine that combines storage for over 180 tools with a space-saving design. Loading/unloading and data editing of tools are available by the dedicated operation panel TOOL HIVE TERMINAL, reducing setup time. Storage can be expanded after the first installation.
*Option
