CNC Turning Centers
HQR NEO
High efficiency 3 turret / 2 spindle CNC turning centers
  • 3 turret / 2 spindle machine construction for faster cycle times
  • Bar work capacity up to Φ4.02" (option)
  • Automation system for various applications from chuck to shaft workpiece
  • The CNC system MAZATROL SmoothG3 for highly efficient machining with 3 turret
Machine construction for a significant reduction in cycle time
In workpieces where there is a difference in machining amounts between the first and second operations, our machine achieves significant productivity improvement even compared to 2 turret / 2 spindle CNC turning center.
Simultaneous three turret machining
Main spindle balance cut (rough O.D.)
Simultaneous upper and lower milling
Bar work capacity
Machine modelMain spindleSecond spindle
HQR-200/3 NEOΦ2.56"Φ2.56"
Φ4.02" *Φ2.56"
HQR-250/3 NEOΦ3.15"Φ2.56"
Φ3.15" *
*: Optional
A variety of automation equipment such as bar feeders, workpiece unloaders and robots are optionally available support long-term automatic operation.
  • Screen design that takes advantage of touch operation speeds up task such as programming and editing.
  • Complex movements of the three turrets are supported by various interference check functions to ensure safe operation.
INTEGREX i-500
3 split display EIA / ISO programming screen
The display divided into three columns makes it easy to confirm the operation of each turret. The EIA/ISO programming screen displays the waiting command positions side by side, enabling intuitive and easy program editing.
Various program check functions
Program checks are also difficult on 3-turret machines because of the complexity of turret movements, which makes it difficult to maintain synchronization of the individual turrets.
These functions support program checking without disrupting the synchronization of the turrets.
Virtual Machining
Safety Shield
This inter-grid single block operation ensures the synchronization between turrets, preventing interference and increasing downtime caused by program misalignment.
A: Turret A
B: Turret B
▲: Operation stop
A: Turret A
B: Turret B
▲: Operation stop
Override synchronized operation
Override, which allows adjustment of program processing time, is reflected not only in the operating time of the turrets but also in the standby time, thus enabling program operation without disrupting synchronization between turrets. This allows for high-accuracy interference checks.
With Override synchronized operation (50%)
A: Turret A
B: Turret B
1: Dwell (standby time)
2: Supporting Functions
3: No program misalignment
Without Override synchronized operation (50%)
A: Turret A
B: Turret B
Manual pulse handle operation
The machining program can be operated at any speed by turning the handwheel of the CNC system by hand. The approach position and points where interference is likely to occur can be carefully checked.
Chuck size: 8-inch
  • Milling
  • Second Spindle
  • Y-axis
HQR-200/3 NEO
Spindle boreΦ2.99"
Chuck size8″
Max. machining diameterΦ12.6"
Max. machining length33.86"
Chuck size: 10 inch
  • Milling
  • Second Spindle
  • Y-axis
HQR-250/3 NEO
Spindle boreΦ3.58"
Chuck size10″
Videos
