CNC Turning Centers
QUICK TURN
Evolving best-selling high-performance CNC turning centers
  • Built-in motor spindle and high rigidity machine construction provide unsurpassed performance
  • Turning, milling, Y-axis and second spindle specifications designed to meet your production requirements
  • Wide range of chuck size and center distance for both small and large machining
QUICK TURN image
Built-in motor spindle, which is equipped on all models of series can perform heavy duty machining of difficult machining materials or ferrous metals, as well as high speed machining of non-ferrous materials such as aluminum. You can select the optimal spindle, including high speed and high torque specifications to meet your machining requirements.
Continuous machining of the first and second process with a second spindle
The second spindle can also perform high-speed and high-quality turning and milling with its built-in motor spindle. C-axis indexing in 0.0001° minimum increments is standard. Contouring is optionally available.
NC tailstock and steady rest
The operator can move the NC tailstock to the correct position and set the optimal thrust force, supporting high-accuracy machining of shaft workpieces. Together, NC tailstock and steady rest effectively suppress and maintain stability of long and small diameter workpieces and large-diameter workpieces machining.
NC tailstock
Steady rest
High rigidity construction
Machine construction and CNC technology provide even more stable machining accuracy
The rigid machine construction is designed to ensure high precision during heavy-duty machining and high-speed feedrates.
Without gear belt, built-in motor spindle minimizes vibration and improves roundness and machined surface accuracy.
Roller guides with excellent speed and durability are used on all axes.
High speed drum turret with minimum interface
Depending on the model, 12 position drum turret, 16 position drum turret and 12 position drum turret (24 position) can be selected. Drum turret with minimum interface and non-lift rotary indexing perform high-speed clamping / unclamping. Tool holder can be selected between bolt-on or VDI.
Bolt-on turret
VDI turret
High precision, high speed spindle
An integral motor is utilized for the turret milling spindle to minimize vibration for high accuracy. The motor unit is cooled to minimize heat generated during high-speed revolution.
A variety of optional automation equipment to increase productivity
Ez LOADER is a space-saving automation system with collaborative robots. With the specialized software, Ez LOADER eliminates tedious robot teaching tasks and can be easily set up by anyone.
Gantry Loader System
The unique structure of the gantry loader system provides unparalleled flexibility, enabling positioning conveyors on its left and right, adding measuring instruments, and connecting two machines. By adding automatic door and robot interfaces, the gantry loader can be retrofit on already installed machines.
The touch panel is intuitive, and the 3D model display allows you to create programs while checking the machining shape and process. It prevents program errors and shortens program creation time. G code programming is also available.
SOLID MAZATROL (Automatic / Conversational Programming)
MAZATROL programs are automatically generated from 3D models created with commercially available CAD/CAM software. An optimal program is generated by learning the appropriate machining pattern for the machining shape from programs created in the past.
Chuck size: 6-inch
Chuck size: 8-inch
Chuck size: 10-inch
Spindle 18.5 kW (25 HP)
Spindle 26 kW (35 HP)
  • Bolt-on
QUICK TURN 300 L
Chuck size10″
Max. Machining DiameterΦ420 mm
Max. Machining Length662 mm / 1282 mm / 1597 mm
  • Milling
  • Bolt-on
QUICK TURN 300MA L
Chuck size10″
Chuck size: 12-inch
Spindle 30 kW (40 HP)
  • Bolt-on
QUICK TURN 350 L
Chuck size12"
Max. Machining Length614 mm / 1234 mm / 1549 mm
  • Milling
  • Bolt-on
QUICK TURN 350MA L
Chuck size12"
  • Milling
  • Y-axis
  • VDI
QUICK TURN 350MY
Chuck size12"
Max. Machining Length629.8 mm / 1224.8 mm / 1564.8 mm / 2079.8 mm
Chuck size: 12 / 15 inch
Spindle 37 kW (50 HP)
  • Bolt-on
QUICK TURN 400 L
Chuck size12"
Max. Machining DiameterΦ580 mm
Max. Machining Length1024 mm / 2074 mm / 3124 mm
  • Milling
  • Bolt-on
QUICK TURN 400M L
Chuck size12"
Max. Machining Length996.5 mm / 2080.5 mm / 3096.5
Chuck size: 18 / 21 inch
  • Bolt-on
QUICK TURN 450 L
Chuck size18"
  • Milling
  • Bolt-on
QUICK TURN 450M L
Chuck size18"
