Max. worksheet width | 60.04" |
Max. worksheet length | 120.08" |
Laser Power | 4.0 kW / 6.0 kW / 8.0 kW |
Laser Processing Machines
OPTIPLEX Ez
Entry-Level 2D laser processing machine combining cutting performance and ease of maintenance.
- Selectable laser oscillator power: 4.0 kW, 6.0 kW, 8.0 kW.
- Designed to provide high-cutting performance for thin to medium material thicknesses and ease of maintenance.
- Ez is the ideal solution for those taking their first step in the laser machining world.
- The machine can be selected in 3015 and 4220 table size.
Equipped with large front and side access doors
Sliding doors are installed on the front and side of the machine, minimizing the floor space requirement. Additionally, slide door on the side of OPTIPLEX 4220 Ez can be opened from both left and right, which makes it easier for the operator to load and unload workpieces.
Improved operability of CNC control
CNC control for 2D laser processing machine
Operator can easily zoom in and out on the display screen with fingertips. The wide screen also allows the operator to check nesting at a glance.
One-touch operation
Assist functions
By simply entering the items suggested by assist functions, operator can easily set up functions such as nozzle center check and automatic nozzle changing.
