Round pipe Max. workpiece diameter | Φ6" |
Square pipe Max. workpiece diameter | 4.92" × 4.92" |
Max. workpiece length (loading) | 255.91" |
Laser power | 3.0 kW |
Laser Processing Machines
FT-150 NEO
- U-axis control provides high-speed, high-accuracy cutting
- The productivity of pipe mass production operation is automated and significantly improved
- Optional drilling and tapping can be performed by just one machine
- Reduced running costs with energy-efficient fiber laser
- New graphical user interface (GUI) of the CNC system greatly improves operability
High quality and high productivity cutting of various pipes
Cutting of a variety of sizes and materials. High-speed, high-accuracy cutting by U-axis control
The FT-150 NEO is capable of processing round pipes with a maximum diameter of Φ6" and square pipes with a size of 5" per side. The laser head can be operated at high speed by U-axis and can cut materials such as mild steel, stainless steel, copper, brass, and aluminum with high speed and high-accuracy.
B-axis for bevel cutting as standard
The laser head with B-axis can cut materials at desired angle. This ensures high-accuracy bevel cutting and improves the quality and strength of the joint.
High-speed feedrate and chuck indexing speed
FT-150 NEO | |
X-axis | 5906 IPM |
Y-axis | 2559 IPM |
Z- axis | 2559 IPM |
B-axis | 19200 deg/min |
C-axis | 54000 deg/min |
U-axis | 2559 IPM |
By integrating the conventional pipe process, the FT-150 NEO reduces inter-process transfers, waiting time, setup time, etc., and completes all processing on a single machine. It shortens production lead time.
Reduce in-process time of pipe processing
Conventional process
1 : Cutting by Saw
2 : Blanking
3 : Bevel cutting with grinder
4 : Drilling
5 : Hole Tapping
FT-150 NEO
A : FT-150 NEO completes all processing on a single machine
Large-capacity bundle loader
Materials are automatically loaded with a large-capacity bundle loader, and after laser processing, the cut parts are automatically unloaded.
After laser processing, the cut parts are automatically unloaded. An operator can interrupt the automaticbundle loading during a scheduled run and load material manually for imperative workpieces.
Rotary Tool Unit for drilling and tapping
Tools suitable for drilling, tapping and chamfering can be attached to the optional rotary tool unit. Also, the thermal drilling function and drill support, a supporter which hold the workpiece during drilling, comes with rotary tool unit as standard.
Thermal Drilling
Various optional functions for high accuracy and value cutting
Work Center Location/Inclination Compensation
Check the work center of pipe material and automatically compensates for material distortion to ensure high precision positioning.
Visual Seam Locator
The weld seam of pipe material can be detected on the machine to determine the required radial position for cutting.
Internal Spatter Guard
The spatter guard protects the internal workpiece surface from spatters and burns, thereby preserving the quality of the workpiece.
Reduce running costs with fiber laser
The advanced technology of the fiber laser provides higher efficiency Since fiber laser processing machines do not require laser gas, they have low power consumption and are easy to maintain.
New graphical user interface specialized for tube processing ensures easier operation. It comes with a dual touch panel with large 21.5" screen. The flow from preparation to processing is displayed on one screen. Condition setting of scheduled operation can be changed and reprocessing can be done on the CNC system easily.
Upper monitor
Lower monitor
The lower monitor assists the operator throughout the produc- tion process. The entire process can be monitored efficiently using the newly designed interface. The operator can modify the condition settings of scheduled operations and even reprocess selected parts with ease on the CNC system.
* option
