Chuck size | 10″ |
Max. machining diameter | Φ700 |
Max. machining length | 1574 mm / 2594 mm / 3074 mm |
INTEGREX i-500
- Ease of operation and compact design of the INTEGREX i series with a large machining area equivalent to that of the INTEGREX e-H series
- Exceptional performance versatility - Special processes, such as gear machining, gear hobbing, and deep drilling with end mills, are now incorporated on one machine, achieving process integration.
A wide variety of specifications to meet your production requirements
A wide range of bed length type for large-diameter and long workpieces. A variety of tailstock, second spindle, and lower turret specifications can be selected, as well as turning spindles and milling spindles. Optimal customization is possible for machining in all industries.
Universal
1: 1500U
2: 2500U
3: 3000U
Second spindle
Standard type 4000 min-1
High output type 3300 min-1
High output and high torque type 2500 min-1
Tailstock
MT No.5 Built-in center
Lower turret
9D (turning/milling)
Compact milling spindle and large machining area minimize interference
The standard compact milling spindle is 17% shorter in overall length than the conventional milling spindle, increasing the machining range and reducing the interference.
Long Y-axis stroke : 430 mm
Max. swing / Max. machining diameter : Φ 700 mm
X-axis Travel: 845 mm
Y-axis Travel: 430 mm
Pursuit even more high-accuracy machining
B-axis and C-axis achieve high-accuracy machining
B-axis is equipped with a roller gear cam with no backlash, and C-axis is equipped with a full circumference disc brake. Both B-axis and C-axis are equipped with high-performance and high-accuracy scales as standard to improve positioning and contouring accuracy.
B-axis: min. indexing increment 0.0001° (roller gear cam)
C-axis: min. indexing increment 0.0001° (full circumference disc brake)
X-, Y-, Z-axis ball screw core cooling as standard
Wide range of milling spindle greatly contribute to productivity improvement
The milling spindle is equipped with a high output and high torque integral spindle / motor. In addition to standard No.40 taper spindle, high speed and high output specifications as well as a No.50 taper spindle are optionally available to meet the various machining requirements.
No.40 standard spindle 12000 min-1
No.40 high output spindle 12000 min-1 *
No.40 high speed spindle 20000 min-1 *
No.50 high output spindle 10000 min-1 *
* Option
4 sizes of spindle bores for turning spindle
Optimal selections based on the machining requirement
The integral spindle / motor makes it ideal for continuous machining of first and second operations.
The first and second turning spindles can be completely synchronized, enabling high-speed, high-accuracy machining of thin, long workpieces.
C-axis (0.0001° indexing increment*) achieves indexing accuracy comparable to that of rotary axis on machining centers by employing a full circumference disc brake and a magnetic detector.
*Standard specification for second spindle is 0.001°.
4000 min-1 standard spindle, Φ91 mm bore
3300 min-1 high output spindle, Φ112 mm bore*
2500 min-1 high output and high torque spindle, Φ132 mm bore*
2000 min-1 high output and high torque spindle, Φ185 mm bore*
* Option
CNC system MAZATROL SmoothAi
MAZATROL SmoothAi offers high operability and high-speed, high-accuracy control, improving productivity by utilizing the Digital Twin, an AI-equipped and advanced digital simulation.
INTEGREX i-500
INTEGREX i-500S
Chuck size | 10″ |
INTEGREX i-500ST
Chuck size | 10″ |
Max. machining length | 1574 mm / 2594 mm |
