Table size | 1740 mm × 750 mm |
Vertical Machining Centers
FJV (BT50)
- Highly rigidity double column construction for high accuracy machining
- High-accuracy built-in motor spindle / motors for high-efficiency machining
- Designed for high efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
- 1: |The double column construction delivers high accuracy machining over extended periods of operation
- 2: |High-accuracy positioning by ball screw and direct servo mounting
- 3: |Spindle temperature control prevents changes in machining accuracy
- 4: |Linear roller guides for high rigidity are used on all axes
Ball screw core cooling
High-accuracy integral spindle / motors for high-efficiency machining
Equipped with a integral spindle / motor, it eliminates the need for driving gear. It can reduce power loss and minimize vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High torque spindle and high speed spindle (BT40) are available as options
A 10000 min -1 standard spindle that can handle machining of various materials such as cast iron, steel, and nonferrous metal , a 7000 min -1 high- torque spindle (optional) that is effective for rough machining of steel and cast iron , and a BT40 18000 min -1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high speed machining are available.
Standard spindle | High torque spindle* | High speed spindle(BT40)* | ||
Cont. rating | 30 kW (40 HP) | 22 kW (30 HP) | 26 kW (35 HP) | |
Cont. rating | 239 N・m | 318 N・m | 57 N・m | |
Tool shank | BT50, | BT50, | BT40, |
- *|Optional
More options to integrate process and achieve high productivity
Multi-surface machining attachment (optional) enables four face machining with one angle tool
An additional axis (optional) that enables control of the 4th axis by commands in the machining program
2-pallet changer (optional) to load the next workpiece during the machining of the current workpiece
3D ASSIST
QUICK EIA
FJV-35/60
FJV-35/80
Table size | 2240 mm × 750 mm |
FJV-35/120
Table size | 3240 mm × 750 mm |
FJV-60/80
Table size | 2240 mm × 1250 mm |
FJV-60/120
Table size | 3000 mm × 1250 mm |
FJV-60/160
Table size | 4000 mm × 1250 mm |
FJV-100/120
Table size | 3000 mm × 2000 mm |
FJV-100/160
Table size | 4000 mm × 2000 mm |
