Max. cutting size (round) | Φ406 mm |
Max. cutting size (square) | 305 mm × 305 mm |
Max. workpiece length (loading) | 6180 mm* ~ 15180 mm* |
Laser power | 4.0 kW / 5.0 kW |
Laser Processing Machines
FG-400 NEO
- Continuous automatic machining of long pipes and structural materials completes in one machine
- 3D laser head cuts and joints complex shapes with high-accuracy
- High-speed cutting by energy-efficient fiber laser
- SmoothTUBE CNC control
High-accuracy cutting by 3D laser head
Cut and joint broader range of materials and complex shape
The 3D laser head processes materials from various angles and directions. L, H, I-beam and channel can be processed as well as round and square pipe materials.
Protection torch
In the unlikely event of the torch striking the material, damage can be minimized as the torch tip itself tilts.
All cutting process in one machine
Automatic loading of materials and unloading of finished parts
- 1: |Automated loading of long materials from loading station
- 2: |Automated unloading of finished parts from unloading station
High-speed feedrate drastically reduces processing time
FG-400 NEO | |
X-axis | 60 m/min |
Y-axis | 36 m/min |
Z-axis | 30 m/min |
C-axis | 17400 deg/min |
High-accuracy cutting while minimizing vibration
Four chucks move and rotate simultaneously to prevent material distortion. Various supporters suppress vibration and provide high-accuracy cutting.
Tapping of long materials by the same machine
Optional tapping is added by attaching tapping unit. FG-400 NEO can accommodate up to M16.
Advantages of process integration
All processes from materials to finished products, including transportation, cutting, bevel cutting, drilling, tapping, and punching, are completed on a single machine. Streamlining production processing and performance, our laser machines offer a wide range of benefits including a reduction in machine setup, production lead time, in-process inventory, the number of machines, fixtures, operators, floor space and higher precision.
Higher efficiency with high-quality fiber laser
The advanced technology of the fiber laser provides higher productivity and higher efficiency
Capable of processing a variety of materials, including highly reflective materials
Fiber laser is capable of high-speed cutting of mild steel, which is difficult to process with CO2 laser cutting machines. It stably cut even highly reflective materials such as aluminum, copper, and brass.
Beam Diameter Control function / Variable Beam Mode function
Beam shaping technology automatically adjusts the beam diameter according to the material and thickness, and controls where the power density of the laser beam is concentrated. Together, these two functions improve the speed and quality of cutting a wide range of materials.
Various optional functions for high accuracy and value cutting
New graphical user interface specialized for tube processing ensures easier operation. It comes with a dual touch panel with large 21.5" screen. The flow from preparation to processing is displayed on one screen. Condition setting of scheduled operation can be changed and reprocessing can be done on the CNC system easily.
Upper monitor
Lower monitor
The lower monitor assists the operator throughout the produc- tion process. The entire process can be monitored efficiently using the newly designed interface. The operator can modify the condition settings of scheduled operations and even reprocess selected parts with ease on the CNC system.
Reference video
* option
