INTEGREX e-V
Simultaneous 5-axis double-column machining center suitable for large workpieces
  • Double-column machining center performs multi-surface machining, free-form surface machining by 5-axis control and turning for higher productivity
  • Highly rigid structure for stable high-accuracy machining
  • Table enhanced with direct drive motor for high torque and high-speed positioning
  • Automation systems to meet your production requirements
  • MAZATROL SmoothAi drives innovation for even higher productivity
Wide range milling with double column construction
High power milling spindle and direct-drive table for turning
Three milling spindles are capable of machining a wide range of materials from steel to non-ferrous materials. All of them achieve compact size and high power by adopting a built-in motor.
High-torque, high-speed table
(turning & C-axis)
A direct drive motor that can output large torque in a compact volume is used to achieve both the high torque required for turning large workpieces and the high response that enables agile positioning.
Compatible models: INTEGREX e-1250V/8, e-1250V/8S, e-1600V/10, e-1600V/10S
High-torque table (turning & C-axis)
The turning spindle, driven by a high power motor and two-gear ranges, performs highly efficient machining of large diameter and heavy workpieces from rough machining to finishing. The C-axis can be indexed in 0.0001° indexing increments for high accuracy machining.
Compatible models: INTEGREX e-1850V/12, e-1850V/12S
Automated systems for diverse workpieces and production volumes
PALLETECH HIGH RISE SYSTEM (2 level) *Compatible with INTEGREX e-1250V/8 only
Flexible system expansion
  • System is scalable according to the production demands
  • Different types of Mazak machines can be flexibly integrated into the system
  • Flexible linkage with peripheral equipment which enhances long-term automatic operation and automation of machining processes
Example: PALLETECH MANUFACTURING CELL (1-level)
 First installation*Example of system expansion 1Example of system expansion 2
Number of machines123
Loading stations122
Pallet stockers61420
  • *|Starter set for the PALLETECH MANUFACTURING CELL (1-level)
CNC system MAZATROL SmoothAi
Max. workpiece size: Φ1450 mm to Φ1500 mm
Max. workpiece size: Φ2050 mm to Φ2300 mm
Max. workpiece size: Φ2350 mm to Φ3500 mm
