Horizontal Machining Centers
HCN-Q
Horizontal machining center for large workpieces with the quill
  • Deep boring of large workpieces
  • Rigid machine structure for heavy-duty machining
  • Designed for high speed and high accuracy performance
Capable of boring deep, large-diameter holes in large parts up to 10 tons
Quill spindle for higher machining efficiency
  • Spindle bearing inside diameter Φ180 mm. The multiple-row front spindle bearings provide the rigidity required for heavy duty machining.
  • Quill diameter Φ130 mm / core cooling available (option)
  • High output, high torque gearless built-in motor spindle (Standard equipment)
Quill Spindle
Maximum Speed3000 min-1
OutputAC 45 kW (60 HP) [40% ED]
Maximum Torque1849 N・m (188.4 kgf・m) [40% ED]
Rigid base, column and high accuracy linear guides
Y-axis twin ball screw
The spindle head is driven by 2 ball screws in the Y-axis.
Vibration is minimized to ensure accuracy stability during high speed machining.
Linear roller guides on the X-, Y- and Z-axis are utilized by the HCN-Q series in order to provide high accuracy and heavy duty machining.
Variety of Attachment*
Optional automatic attachment changer increases parts processing flexibility through the use of various special operation attachments
* Compatible with HCN-12500Q, 16000Q, 16800Q (optional)
U-axis boring attachment
Deep hole taper boring
Angle attachment
Top surface machining
U-axis facing attachment
Outside diameter taper machining
Snout attachment
Deep hole machining
Automation available from single machine to a large-scale system
2-pallet changer*
The 2-pallet changer allows the unloading of a finished workpiece and the loading of the next workpiece during the machining of the current workpiece. It can handle heavy workpieces, and its stable, long-term operation improves productivity.
PALLETECH SYSTEM*
This automated system makes it possible to achieve long-term unmanned operation of large workpieces, significantly shortening lead times. It is designed for convenient system expansion after the initial installation to easily respond to increased production requirements in the future.
Pallet size: 1250 mm x 1000 mm
Photo: HCN-16000QS
Maximum workpiece height: 1800 mm
Pallet size: 1600 mm x 1250 mm
Maximum workpiece height: 2000 mm
Maximum workpiece height: 2400 mm
