Vertical Machining Centers
FF-400V/30 L
FF-400V/30
High-performance BT30 vertical machining centers
  • Compact and highly rigidity machine equipped with a high-speed BT30 spindle for small parts machining
  • Table type is selectable to meet your machining requirements
  • Z-axis stroke of 400 mm and maximum tool length of 250 mm allows machining large workpieces
  • Rapid traverse rate 60 m/min (all axis) and high acceleration (X/Y/Z = 1.1/1.2/1.9G)
Equipped with high speed, high accuracy, compact BT30 spindle for small parts machining
Compact, high performance 12000 min-1 standard spindle. Designed to perform a wide variety of machining efficiently.
20000 min-1 high speed spindle (optional)
High speed armless tool changer
The standard tool storage capacity is 14, and 26 is available as an option.
High speed positioning
X-, Y- and Z-axis rapid traverse rate 60 m/min
Table Variation
Fixed table (FF-400V/30 L)
Equipped with a 600 mm × 400 mm fixed table. There is enough machining area even with a tall hydraulic fixture on the top face of the table.
1: Distance from spindle nose to table top 190 - 590 mm 2: 600 mm 3: Table height 735 mm
A-axis table (FF-400V/30 L)
The A-axis table allows indexing at any angle. This improves productivity by enabling the machining of top, side and slanted surfaces in a single setup.
The cradle that connects the rotary table on both sides is a jig. This is not included with the machine.
A- and C-axis table (FF-400V/30)
Equipped with a high-rigidity 2-axis rotary table(A-axis and C-axis) with support on both ends. Simultaneous 4-axis + A-axis indexing enables multi-surface continuous machining from any angle, achieving process integration.
Ergonomic design for ease of operation
Wide opening and lightweight front door
The front door is designed for easy opening and closing to reduce the load on the operator when loading and unloading workpieces.
Excellent access to table and spindle
Workpiece loading / unloading, fixture changing, and checking the spindle tool can all be done in a natural posture. Standard cover coolant prevents the accumulation of chip, and centering conveyor structure discharges chip directly under the table, which reducing the workload of the operator.
The digital setup function can replicate the machine of your factory in the PC at your office. On the machine side, operation programs can be created while checking the workpiece shape and process, intuitively with touch panel controls.
FF-400V/30 L
FF-400V/30
FF-400V/30 L
Tool shank (standard)BT30
Table size600 mm × 400 mm
