Pallet size | Φ500 mm × 400 mm |
Max. workpiece size | Φ500 mm × 350 mm |
5-Axis Machining Centers
VARIAXIS j
- Rigid trunnion table design supports table on both sides for heavy duty machining. High-accuracy machining is possible
- 0.0001° indexing increment for a variety of multiple-surface machining (simultaneous 4-axis + A-axis indexing) [j-500].
- Simultaneous 5-axis control for 3-dimensional curved surface machining [j-500/5X].
- Excellent accessibility to the table and magazine in front of machine for easier operation.
Machine structure for high-accuracy machining
1: Linear roller guides utilized on the X-, Y- and Z-axis
The linear roller guides on the X-, Y- and Z-axis utilized by the VARIAXIS j series provide high-accuracy positioning.
Additionally, with their high rigidity and considerably lower friction, high speed feedrates can be used over a wide range of machining, from heavy-duty to high speed cutting.
2: High rigidity table
High rigidity tilting rotary table for high speed and high accuracy machining.
3: Rotary axis equipped with roller gear cams
The VARIAXIS j series tilt and rotary tables use roller gear cams for superior accuracy, rigidity, and durability. Elimination of backlash ensures high accuracy and high efficiency machining.
Axis configurations designed for various multiple-surface machining and 5-axis machining
Multi-surface machining: VARIAXIS j-500
(CNC: MAZATROL SmoothG)
Simultaneous 5-axis machining: VARIAXIS j-500/5X
(CNC: MAZATROL SmoothAi)
High-rigidity, high-speed spindle for a wide variety of materials
Standard spindle
maximum spindle speed | 12000 min-1 (rpm) |
Output [40% ED] | 11 kW (15 HP) |
Torque [40% ED] | 65.1 N・m |
High speed spindle (Optional)
Max. spindle speed | 18000 min-1 (rpm) |
Output [40% ED] | 15 kW (20 HP) |
Torque [40% ED] | 59.7 N・m |
Applications
Aerospace component
Fastener
Food logistics component
Bracket
General industry component
Blower
Automotive component
Control arm
Stable machining accuracy over long periods of operation
High-Accuracy 5-axis Calibration MAZA-CHECK
Position misalignment and incline of the rotary axis can automatically be measured and compensated to realize high accuracy 5-axis machining.
In addition to offsetting position deviation traveling parallel to the linear axis, angular deviation due to tilt direction can also be corrected.
- * |Wireless touch probe RMP600 is optional equipment.
- * |Optional function for VARIAXIS j-500.
Based on spindle speed and temperature of the machine, Ai Thermal Shield suppresses changes in the cutting edge position. It stabilizes continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors. Furthermore, by accumulating and learning data from subsequent measurements, thermal displacement compensation can be optimized for each machining environment.
- machining
- Workpiece Measurement
- Optimization Simulation
2-pallet changer (Optional)
The VARIAXIS j series offers the 2-pallet changer as an option.
The next workpiece can be setup during the machining of the current workpiece for higher productivity.
Large reduction of total production time
The VARIAXIS j-500 series incorporates all machining processes from raw material input through final machining – in just one machine. It provides the ability to reduce production lead time, improve machining accuracy, reduce floor space and initial cost, lower operating expenses, reduce operator requirements and to improve the work environment. As a result, it not only streamlines production, it also improves overall management.
Previous production method
Horizontal machining centers × 2
Fixtures and tools × 2
Operator × 2
Large in-process inventory / in-process time
VARIAXIS j-500
VARIAXIS j-500 × 1
Fixtures and tools × 1
Operator × 1
Small in-process inventory / in-process time
