Mass Production
Mazak delivers a large number of machine tools to the mass production manufacturing sector, including the automotive, consumer electronics and construction industries. Mazak offers an extensive line-up of machine tools, from machines that form dedicated lines for machining mass-produced parts to general-purpose machines that can easily be lined and automated, as well as 5-axis and multi-tasking machines for machining parts for prototype production. Mazak's experience and track record are utilized to provide one-stop proposals for machine tool selection, machining technology, jigs and tools, software and measuring equipment. We also provide support for smooth start-up after the introduction of equipment. With our technology centers around the world as support bases, Mazak not only sells machine tools, but also provides global technical support by application engineers to build production lines tailored to the customer's manufacturing processes.
Applications
Mazak's machine tools are used for mass production parts
QUICK TURN Series
High-performance CNC turning center
Turning, milling, Y-axis and second spindle specifications designed to meet your production requirements
HCN NEO Series
High-speed, high-precision horizontal machining center
High performance machine tool NEO series with high productivity and environmental performance
MULTIPLEX W Series
Symmetrical Machine Design with 2 Spindles and 2 Turrets
Capable of multiple processing methods; turning, drilling, contour milling, and Y-axis machining
HQR Series
CNC turning center with milling and Y-axis function
2 turret / 2 spindle configuration for significantly reduced cycle time
DUAL TURN 200 Series
2 turret / 2 spindle CNC turning center
Simultaneous machining on both spindles and automatic transfer from first to second spindle enables continuous machining
MEGA TURN Series
Vertical CNC turning center
Highly efficient machining of large cylindrical parts; two machines can be arranged, a standard machine and a symmetrical machine
INTEGREX i-H Series
From turning to 5-axis machining using the Y- and B-axis, this single machine integrates multiple processes
VARIAXIS i NEO Series
Simultaneous 5-axis vertical machining center
