Tool shank | BT40 |
Max. workpiece size | Φ730 mm × 1000 mm |
Max. spindle speed | 1000 min-1 (rpm) |
INTEGREX i-V
- Free-form surface machining by 5-axis control as well as multi-surface machining
- Multi-tasking function including turning enhances productivity
- Integrated with various types of automation system, including large-scale systems available
Excellent performance in turning, surface machining, and 5-axis machining
Highly rigid machine structure for stable high-accuracy machining
Linear roller guides with excellent rigidity are utilized in the X-, Y- and Z-axes to achieve powerful cutting and high-accuracy machining.
B-axis roller gear cam
The backlash-free roller gear cam ensures high positioning accuracy, which is twice as good as the ISO standard over the entire 150 degree rotary range of B-axis.
Cone coupling
Y-axis slant structure
Applications
Automation systems to meet your production requirements
MAZATEC SMS
Advanced logistic system for Smart Factory. The pallet stocker type automation system with AS/RS technologies is fully customizable and achieves large capacity and space efficiency.
PALLETECH SYSTEM
The scalable automation system, which consists of pallet stockers, a pallet loader robot, and loading stations, can be flexibly expanded to accommodate increases in production. It is available in a wide range of system layouts, including one, two and three level configurations.
Smooth Ai spindle*
* Option
SMOOTH MACHINING CONFIGURATION (convenient parameter setting and fine tuning function)
MAZA-CHECK (high-accuracy 5-axis calibration)
To ensure 5-axis machining accuracy, MAZA-CHECK measure and calibrate three values; first is the distance between the milling spindle center and table center of rotation (X-axis direction and Y-axis direction), second is the deviation between the B-axis center of rotation and the milling spindle center, and third is the offset amount between the B-axis center of rotation and the milling spindle edge surface. This calibration process is done automatically using a standard sphere, touch sensor*, and measurement macro.
- * |The RMP-600 wireless type high precision touch sensor is required.
CNC system MAZATROL SmoothAi
