Programming and Setup support for Laser Processing Machines
MAZAK SMART SYSTEM
CAD / CAM system that drastically reduces preparation time in sheet metal processing
MAZAK SMART SYSTEM easily allocates parts based on drawings and instantly creates development drawing and work instructions which can be directly imported into the CNC system. Nesting data with the highest yield can be created instantly. In traditional CAM systems, the design process in CAD, manual nesting, creation of NC data using CAM, and nesting take a significant amount of time. However, our MAZAK SMART SYSTEM consolidates all of these processes into a single system. This allows for a reduction in lead time of over 25% compared to conventional methods. Additionally, it is possible to manage a vast number of programs collectively, and network setup is also made easier.
- Easy creation of solid modelling from orthographic drawings
- Instant creation of development drawings and work instructions
- Converted directly into NC data. Nesting data with the highest yield can be generated instantly.
TUBE DX
CAD / CAM system for pipe cutting
Instantly create an easy operational program for 3D cutting of tube or pipe.
Utilising automatic nesting results in increased yield and reduces material waste.
The production status can be checked at a single glance with the scheduling function.
Automatic batch mode significantly reduces work time.
