CNC for Laser Processing Machines
MAZATROL CNC ever evolving with Mazak laser machines
When it comes to laser processing machines, not only the performance of the machine itself is important, but also the control technology, operability and network. Over the past 30 years, the Mazak CNC systems have evolved with advanced technology, leading to the development of dedicated systems for 2D and 3D laser processing machines. With the system, the Mazak laser machines can be operated at their full potential at all times.
CNC control for 2D laser processing machines
Operator can easily zoom in and out on the display screen with their fingertips. The wide screen also allows the operator to check nesting at a glance.
Apart from the emergency stop and rotary switch buttons, operational buttons feature a flat design. The use of pictograms makes operation more intuitive.
Dual Monitor
Operator can work while referring to the cutting area and manual.
* Dual Monitor is optionally available on OPTIPLEX NEO.
One-touch operation
Assist functions
By simply entering the items suggested by assist functions, the operator can easily set up functions such as a nozzle centre check and automatic nozzle change.
Advanced hardware
State of the art CPU. With unsurpassed operation speed, the machine operates with high-response and high-speed.
Optimal acceleration / deceleration reduces cutting time
Tolerance control prevents the corner shape from collapsing even when acceleration is maximised.
Laser operation responsiveness is greatly improved
The laser control has been enhanced to instantly control and allocate the optimal laser power. It performs to its full capacity for sharp edge cutting and flash cut.
19” LCD screen and touch panel
The large screen with a touch panel displays information in an easy-to-read format. There is no need to move eyes from the screen when entering data, enabling high work efficiency.
Operation switches
Large switches and highly visible LEDs prevent operational errors. Unused buttons can be turned off, so that the user can see at a glance whether a function is enabled or disabled. In addition, the buttons have been categorised and arranged according to function to improve operability.
Check the 5 screens divided into each process and start processing
- Maintenance items status
- Check programme cutting shape
- Torch status display
- Peripheral equipment ON/OFF, alarm
- Cutting path, work coordinate and axis speed
Touch panel type CNC system for ease of operation
15” touch panel colour LCD screen as standard. The simple and easy-to-understand screen layout improves operability. Frequently used displays, such as the command screen, position screen, and programming screen can be easily moved. Optimal acceleration / deceleration control enables both stable high-speed and high-accuracy cutting and reduction of cutting time.
CNC control for 3D laser processing machines
New generation CNC system specialised for pipe processing
3D laser processing of pipes and structural materials can be easily achieved with high-accuracy. Through years of development, the system has incorporated accumulated expertise to greatly enhance operability and productivity.
- New graphical user interface specialised for tube processing ensures easier operation
- With the flow from preparation to processing displayed on one screen it is easy to operate
- Condition setting of scheduled operation can be changed and reprocessing can be done on the CNC system easily
