5-axis Machining Centres
VTC-800 Series
VTC Series
Traveling column vertical machining centre for 5-axis machining
Designed to meet the demands of diverse manufacturing applications. The Vertical Travelling Column (VTC) series of the Vertical Machining Centres offers flexibility, high-quality, and precision for optimal performance.
  • Enhanced productivity through easy to program MAZATROL CNC
  • Flexibility to meet changing application needs.
  • Delivers class-leading accuracy and repeatability.
Full view of VTC-800/30
Increased Productivity
Performance spindles to meet your application needs
  • The latest generation spindle with hybrid ceramic bearing technology delivers high-performance machining capability with outstanding reliability.
VTC-800 SR, SDR, SLR, models
Maximum milling spindle speed18,000 min-1
Milling spindle power35 kW (50% ED)
Maximum torque168 Nm
Class-leading axis performance
  • Experience class-leading performance with the integration of the latest drive, motor and roller linear guide technologies, delivering high-speed rapid and feed traverse rates.
AxisRapid Traverse rateFeed rate
X-axis50 m/min1 - 50.000 mm/min
Y-axis50 m/min1 - 50.000 mm/min
Z-axis50 m/min1 - 50.000 mm/min
B-axis
(SR, SDR, SLR only)
50 min-1
C-axis*125 min-1
A-axis*225 min-1
*1: SR option, SLR standard
*2: SDR A1 & A2 axes standard
VTC-800SR Series
Large 4-axis with optional 5-axis
  • Available 2000 or 3000 mm X-axis and 800 mm Y-axis.
  • B-axis swiveling head enables 5-face machining and 5-axis simultaneous machining when combined with the NC rotary table option.
VTC-800/30 spindle
  • Options for a centre partition and left-hand or right-hand NC rotary tables (with vertical or horizontal mounting) provide various alternative machining configurations.
VTC-800/30 spindle
VTC-800SDR Series
6-axis tables designed with dual synchronous NC rotary tables
  • Designed with class-leading working envelope, integrated dual synchronised NC rotary tables.
  • Featuring a high-performance 18,000 min-1 spindle and highly efficient large-volume chip disposal.
  • The B-axis swivel head can be positioned at 5-degree increments for heavy cutting.
VTC-800/30 spindle
VTC-800/30SLR
5-axis, large integrated NC rotary table
  • Full 5-axis capability through the integrated large-diameter rotary table and swivelling head.
  • Large doors provide optimum operator access for load, set-up and unloading.
  • Movable pendant ensures efficient workpiece set-up.
VTC-800/30 spindle
MAZATROL CNC Systems
CNC systems that can be selected according to ease of use and processing applications.
Supported models
VTC-800SR series, VTC-800SDR series, VTC-800/30SLR
VTC-800
VTC-800/20SR
Table size2500 mm × 820 mm
Tool shank (standard)CAT No.40
Max. spindle speed18000 min-1
VTC-800/30SR
Table size3500 mm × 820 mm
VTC-800/20SDR
Table sizeΦ500 mm
Max. workpiece sizeΦ820 mm × 2690 mm
VTC-800/30SDR
Table sizeΦ500 mm
Max. workpiece sizeΦ820 mm × 3690 mm
VTC-800/30SLR
Table size3500 mm× 820 mm
