5-Axis Machining Centres
VORTEX e-V
Simultaneous 5-axis vertical machining centres for stable, high-accuracy machining
  • High-accuracy machining with double column structure
  • A direct drive motor for table swivel axis (C-axis) is equipped for high-speed cutting feed during 5-axis machining
  • Automation systems for diverse workpieces and production volumes
VORTEX e-V image
Wide range milling with double column structure
Double column construction suitable for top face machining of large workpieces
By utilising a double column structure together with long axes strokes, top face milling can be performed with only linear X- and Y-axis positioning, resulting in stable machining accuracy and higher productivity.
temp
Direct drive motor for high-speed cutting feed in 5-axis machining
High-speed, high-precision table (C-axis)
The table uses a direct drive motor for high-speed C-axis feed. Since a direct drive motor directly delivers power to C-axis with less power loss, high-speed feed is ensured with 5-axis control for enhanced productivity.
1: Direct drive motor
PALLETECH HIGH RISE SYSTEM (2 levels)
  • *Compatible only with VORTEX e-1250V/8
  • Flexible system expansion is possible in response to changes of production volume
  • Different types of Mazak machines can be integrated into the system
  • Flexible linkage with peripheral equipment and systems that increase the rate of automation of long-time automatic operations and machining processes
  • Example: PALLETECH MANUFACTURING CELL (1 level)
*The starter set is the required configuration of PALLETECH MANUFACTURING CELL (1 level)
MAZATROL SmoothAi CNC system
MAZATROL DX
The same environment as the actual MAZATROL SmoothAi machine can be reproduced on an office PC using digital twin technology.
Multiple virtual machines can be built, which can make programming, editing, simulation and function analysis possible.
The setting data of the actual machine is synchronised, which ensures the accuracy of the digital setup.
Automation
Software development and functions to support automation
Pallet size: 800 mm × 800 mm
Pallet size: Over 1000 mm × 1000 mm
