CNC Turning Centres
SLANT TURN
Heavy-duty machining of large, long shaft workpieces
  • Powerful cutting of large-diameter workpieces with high-torque spindles
  • Machine construction with high-rigidity roller guides
  • Wide range of spindle bores up to Φ375 mm
Max. machining diameter Φ 910 mm
Max. machining length 1016 mm to 4099mm
Spindle bore variations
Φ 185 mm
SLANT TURN
500, 500M
Φ 275 mm
SLANT TURN
550, 550M
Φ 320 mm
SLANT TURN
550, 550M
Option
Φ 375 mm
SLANT TURN
600, 600M
High-torque for powerful cutting of large-diameter workpieces
Achieves high-efficiency machining with full power even in low speed ranges.
Max. torque7000 N・m
Main spindle power45 kW(60 HP)
High-power milling spindle that rival those of small machining centres
SLANT TURN 500M, 550M, and 600M are capable of highly efficient milling / turning. A high-torque version is also optionally available.
VDI-type Turret (Milling setup)
Bolt-on turret (Standard setup)
Automatic steady rest with significantly reduced travel time
The maximum available steady rest size is Φ410 mm - largest for this turning center class. Positioning time is considerably reduced with operation by CNC. The tailstock can approach much closer to the steady rest for an expanded machining area.
Tailstock to handle both long and short shaft workpieces
The tailstock quill can extend 250 mm making it possible to support both long and short shaft workpieces.
This eliminates the need to remove the steady rest when changing the workpiece from long to short shaft.
SLANT TURN
Spindle bore: Φ185 mm
Spindle bore: Φ275 mm
Spindle bore: Φ375 mm
