Chuck size | 6″ |
Max. Machining Diameter | Φ280 mm |
Max. Machining Length | 340 mm |
CNC Turning Centres
QUICK TURN
- Built-in motor spindle and high-rigidity machine construction provide unsurpassed performance
- Turning, milling, Y-axis and second spindle specifications designed to meet your production requirements
- Wide range of chuck size and centre distance for both small and large machining
Built-in motor spindle, which is equipped on all models of series can perform heavy-duty machining of difficult machining materials or ferrous metals, as well as high-speed machining of non-ferrous materials such as aluminium. You can select the optimal spindle, including high-speed and high-torque specifications to meet your machining requirements.
Continuous machining of the first and second process with a second spindle
The second spindle can also perform high-speed and high-quality turning and milling with its built-in motor spindle. C-axis indexing in 0.0001° minimum increments is standard. Contouring is optionally available.
NC tailstock and steady rest
The operator can move the NC tailstock to the correct position and set the optimal thrust force, supporting high-accuracy machining of shaft workpieces. Together, NC tailstock and steady rest effectively suppress and maintain stability of long and small diameter workpieces and large-diameter workpieces machining.
High-rigidity construction
Machine construction and CNC technology provides even more stable machining accuracy
The rigid machine construction is designed to ensure high-precision during heavy-duty machining and high-speed feedrates.
Without a gear belt, built-in motor spindle minimises vibration and improves roundness and machined surface accuracy.
Roller guides with excellent speed and durability are used on all axes.
High-speed drum turret with minimum interface
Depending on the model, 12 position drum turret, 16 position drum turret and 12 position drum turret (24 position) can be selected. Drum turret with minimum interface and non-lift rotary indexing perform high-speed clamping / unclamping. Tool holder can be selected between bolt-on or VDI.
High-precision, high-speed spindle
An integral motor is utilised for the turret milling spindle to minimise vibration for high-accuracy. The motor unit is cooled to minimise heat generated during high-speed revolution.
A variety of automation systems available to increase productivity
The Ez LOADER is a space-saving automation system with collaborative robots. With the specialised software, the Ez LOADER eliminates tedious robot teaching tasks and can be easily set up by anyone.
Gantry Loader
The unique structure of the gantry loader provides unparalleled flexibility, enabling positioning conveyors on its left and right, adding measuring instruments, and connecting two machines. By adding automatic door and robot interfaces, the gantry loader can be retrofitted on already installed machines.
The touch panel is intuitive, and the 3D model display allows you to create programmes while checking the machining shape and process. It prevents programming errors and shortens programme creation time. G code programming is also available.
MAZATROL DX transforms the manufacturing process
MAZATROL DX is a digital service that revolutionises the work process. It supports your work from automatic programming to setup work on the machine. In addition, it has essential functions for part machining, such as ‘Quick Quote’ that automatically generates machining cost estimation.
QUICK QUOTE (Automatic Quotation)
Anyone can easily and quickly create quotations from 3D models. Machining cost, machining time and required tools are automatically calculated in about 30 seconds. The programme and other information used in the quotations is accumulated, so it can be used in later processes.
SOLID MAZATROL (Automatic / Conversational Programming)
MAZATROL programmes are automatically generated from 3D models created with commercially available CAD/CAM software. An optimal programme is generated by learning the appropriate machining pattern for the machining shape from programmes created in the past.
SETUP GUIDE (Tools・Fixtures・Materials Mounting・Automatic Measurement)
Automatic generation of setup instructions enables smooth installation and measurement work. It supports efficient and reduces the number of errors for machine setup.
Spindle 18.5 kW (25 HP)
Spindle 26 kW (35 HP)
Spindle 30 kW (40 HP)
Spindle 37 kW (50 HP)
