Max. worksheet width | 1525 mm |
Max. worksheet length | 3050 mm |
Laser power | 3.0 kW / 4.0 kW / 6.0 kW / 8.0 kW / 10.0 kW / 12.0 kW / 15.0 kW / 20.0 kW |
Laser Processing Machines
OPTIPLEX NEO
- Selectable laser oscillator power: 3.0, 4.0, 6.0, 8.0, 10.0, 12.0, 15.0, 20.0 kW
- Beam Diameter Control function and Variable Beam Mode function for optimum cutting of various materials and thicknesses
- Design focused on accessibility and ease of operation
- Intelligent functions to automate the setup work
- MAZATROL SmoothLx CNC control
High-speed and high-quality cutting
Beam Diameter Control function / Variable Beam Mode function *
Beam shaping technology automatically adjusts the beam diameter according to the material and thickness, and controls where the power density of the laser beam is concentrated. Together, these two functions improve the speed and quality of cutting a wide range of materials.
- *Variable Beam Mode function is only available for laser oscillators with specific power capabilities: 6.0, 10.0, 15.0, 20.0 kW
For thinner material
Laser power | 3.0 kW | |
Features | Beam Diameter Control function | 〇 |
Variable Beam Mode function | ー |
Material: Mild steel / Thickness: 1.0 mm / Assist gas: Nitrogen
For medium to thick material
Laser power | 4.0 kW | |
Material: Stainless steel / Thickness: 14 mm / Assist gas: Nitrogen
For thicker material
Laser power | 6.0 kW / 10.0 kW / 15.0 kW / 20.0 kW | |
Variable Beam Mode function | 〇 |
Material: Mild steel / Thickness: 32 mm / Assist gas: Oxygen
Wide open doors for easy loading and unloading
Wide opening doors
Sliding doors are installed on the front and side face of the machine, minimising the floor space required. The doors are designed to provide generous space. The OPTIPLEX 3015 NEO features a front opening of 1200 mm and a side opening of 3210 mm. The OPTIPLEX 4220 NEO features a front opening of 1190 mm and a side opening of 3130 mm. It ensures easier loading and unloading.
Easy adjustment of nozzle centre
Integrated Nozzle Camera (option)
A camera can be mounted next to the nozzle holder to check the centre position of the nozzle. The nozzle centre can be easily adjusted by turning the dial while viewing the operation screen.
Automatic detection of machining area for nesting
Camera Network Nesting (option)*
Camera inside the machine detects the remnant material and automatically identifies the cutting area for nesting.
- *MAZAK SMART SYSTEM is required for Camera Network Nesting.
Wide and flat screen for easier operation
CNC system MAZATROL SmoothLx
Operators can see the entire nesting board at a glance with the 21.5” wide screen. Apart from the Emergency Stop and Rotary Switch buttons, operational buttons feature a flat design. Pictograms make the operation more intuitive and user-friendly.
