Subcontractor
Parts machining in subcontractors is required in a wide range of industries which constantly demand high-machining quality, reduced costs and short delivery times. In order to process a wide variety of parts with fewer man-hours and lower costs, it is necessary to propose the most suitable machine tools, machining technology and tools for the customer's production system. In recent years, more and more customers have adopted robots and automation systems in response to labour shortages and productivity improvements. Mazak offers a wide range of 5-axis and multi-tasking machines that reduce lead times through process integration, as well as a large number of machine tool lines for different workpiece sizes, materials and shapes. Furthermore, these machine tools can be flexibly linked to robots and automation systems, so that they can operate continuously without personnel at night and on weekends and holidays, which significantly reduces production costs. Mazak provides total support for the automation of factory equipment, from production start-up and operation to service and maintenance.
Applications
Various Mazak machine tools are used in subcontractors
QUICK TURN Series
High-performance CNC Turning Centre
Turning, milling, Y-axis and second spindle specifications designed to meet your production requirements
SLANT TURN Series
Large CNC Turning Centre
Highly productive CNC Turning Centre with large spindle bore diameter, reducing turning cycle times for long shaft workpieces
MEGA TURN Series
Vertical CNC Turning Centre
Highly-efficient machining of large cylindrical parts; two machines can be arranged, a standard machine and a symmetrical machine
INTEGREX i-H Series
Simultaneous 5-axis Horizontal Multi-Tasking machine
From turning to 5-axis machining using the Y-axis and B-axis, this single machine integrates multiple processes
VTC Series
Travelling column type Vertical Machining Centre
Fixed long table can be flexibly used for machining long workpieces in a small floor space
VARIAXIS i NEO Series
Simultaneous 5-axis Vertical Machining Centre
The high-performance NEO series with high-productivity and low environmental impact technologies
HCN Series
Horizontal Machining Centre
A wide range of spindle variations and a highly-rigid structure for highly-efficient machining
HCN NEO Series
High-speed, high-precision Horizontal Machining Centre
High performance machine tool NEO series with high-productivity and environmental performance
INTEGREX j Series
Entry model Multi-Tasking machine
From turning to multi-surface machining using the Y-axis and B-axis, this single machine integrates multiple processes
