Tool shank | BT50, CAT No.50 |
Max. workpiece size | Φ1250 mm × 1250 mm |
Max. spindle speed | 500 min-1 |
INTEGREX e-RAMTEC
- Long X-axis and Y-axis strokes for high-accuracy machining of large parts
- Ram spindle for deep inner diameter boring and milling
High-accuracy machining with double column construction
Double column construction suitable for top face machining of large parts
X-axis stroke
Ram spindle mounted on 5-axis controlled vertical multi-tasking machines
Ram spindle
The ram spindle with a vertical stroke of 900 mm, mounted next to the milling spindle, performs deep inner diameter turning and milling that cannot be machined even with long tools, thus achieving further process integration.
Automatic ram spindle tool changer
A dedicated tool magazine can hold 40 turning and milling tools. The machine can handle a wide variety of machining and change to spare tools during long-term machining.
Milling spindle
Built-in motor milling spindle is both compact and high power. In addition to the 10,000 min-1 standard spindle for various materials, there is a 5,000 min-1 optional spindle suitable for high-torque machining of difficult-to-machine materials and a 15,000 min-1 optional spindle that enables high-speed machining.
The B-axis (travel: 150°) is indexed and positioned with high precision over the long term using a roller gear cam which eliminates backlash.
Turning spindle
The high-power, high-torque turning spindle performs efficient rough machining and finishing of large-diameter, heavy-duty workpieces. In addition, the C-axis can position in 0.0001° increments and ensures high-accuracy machining.
Higher productivity in multi-product machining
2-pallet changer for efficient setup
2-pallet changer promptly replace pallets loaded with heavy workpieces. Setup station rotates with high precision. In addition, the optional workpiece centring tool supports the operator to smoothly perform the alignment work required for turning.
TOOL HIVE*
The TOOL HIVE is a rack-type magazine that combines storage for over 180 tools with space-saving design. Loading/unloading and data editing of tools are available by the dedicated operation panel TOOL HIVE TERMINAL, reducing setup time. Storage can be expanded after the first installation.
*Option
