Vertical Machining Centres
FJV (BT40)
High-accuracy BT40 double column machining centres
  • Double column construction designed for high-accuracy machining over extended periods of operation
  • BT40 high-rigidity spindle for the latest cutting technologies, from heavy cutting to high-speed machining
  • CNC system can be selected from MAZATROL SmoothG and MAZATROL SmoothC
Panoramic view of FJV-250
FJV BT40 processing scene
  • 1: The double column construction delivers high accuracy machining over extended periods of operation
  • 2: High-accuracy positioning by ball screw and direct servo mounting
  • 3: Spindle temperature control prevents changes in machining accuracy
  • 4: Linear roller guides for high-rigidity are used on all axes
FJV BT40 machine structure
Ball screw core cooling
Temperature controlled cooling oil circulates through the ball screw cores. It ensures stable machining accuracy over extended periods of high-speed operation.
Symmetrical headstock design
The symmetrical headstock design together with the integral spindle / motor minimises spindle displacement due to heat generated by the spindle operation.
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF, and other factors.
*Available with the MAZATROL SmoothG.
High-accuracy built-in motor spindle for high-efficiency machining
From nonferrous metals to high-hardness materials, the machine provides high-efficiency machining for a variety of applications in the semiconductor, electronics, aircraft, and mould industries.
Spindle variation from high-torque to high-speed machining
  • 12000 min-1 standard spindle for a wide range of applications from nonferrous metal to steel cutting
  • 12000 min-1 high-torque spindle (option) for heavy-duty, rough machining of steel and cast iron
  • 18000 min-1 high-speed spindle (option) for machining of aluminium, copper, and other similar materials
  • 25000 min-1 high-speed spindle (option) for high-speed die machining with small diameter end mills.
FJV BT40 spindle
FJV BT40 quartz sample work Quartz: Sample workpiece
FJV BT40 aluminium aerospace bracket Aluminum: Aerospace bracket
FJV BT40 prehardened steel mould for automobile component Prehardened steel: Mould for automobile component
Unsurpassed ease of operation with touch screen. A wide range of applications supports from setup to machining.
MAZATROL SmoothC
MAZATROL SmoothC
Simplified display and key input operation
FJV series (BT40)
