Vertical Machining Centres
FJV 5 Face
High accuracy, 5-surface double column machining centre
  • Units and functions that make 5-surface machining accessible as standard equipment, achieving process integration
  • Highly rigidity double column construction for high-accuracy machining
  • High-accuracy built-in motor spindle for high-efficiency machining
  • Designed for high-efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
  • Equipped with touch screen CNC system MAZATROL SmoothG
Units and functions that make 5-Face machining accessible as standard equipment
Four side face machining with one angle tool
The MAZAK 5 Face angle head is capable of powerful cutting with its unique hydraulic pressure clamping unit that provides a strong fixation.
Wide angle head cutting range
Compact angle head reduces interference with the workpiece for large machining area.
Enhanced versatility
The dedicated angle tool magazine has a storage capacity of 8 tools, which makes it possible to handle a wide variety of workpieces.
Simplified programming
The MAZATROL conversational program for 5-surface machining makes it easy to create programs for side face machining.
  • 1: The double column construction delivers high-accuracy machining over extended periods of operation
  • 2: High-accuracy positioning by ball screw and direct servo mounting
  • 3: Spindle temperature control prevents changes in machining accuracy
  • 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Based on spindle speed and temperature of the machine, the Ai Thermal Shield suppresses changes in the cutting edge position. It stabilises continuous machining accuracy through meticulous machine control that takes into account temperature changes, machine position, coolant ON/OFF and other factors.
Equipped with a built-in spindle, it eliminates the need for driving gear. It can reduce power loss and minimise vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High-torque spindle and high-speed spindle (BT40) are available as options
A 10000 min-1 standard spindle that can handle machining of various materials such as cast iron, steel, and nonferrous metal. A 7000 min-1 high-torque spindle (optional) that is effective for rough machining of steel and cast iron. A BT40 18000 min-1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high-speed machining are available.
  Standard spindleHigh-torque spindle*High-speed spindle(BT40)*
Max speed
10000 min-1
7000 min-1
18000 min-1
Motor output
30 min. rating [40%ED]
37 kW (50 HP)
30 kW (40 HP)
35 kW (47 HP)
(Cont. rating)
30 kW (40 HP)
22 kW (30 HP)
26 kW (35 HP)
Motor torque
350 N・m
442 N・m
84 N・m
(Cont. rating)
239 N・m
318 N・m
57 N・m
Tool shank
BT50,
CAT No.50,
BIG-PLUS NO.50*,
HSK-A100*
BT50,
CAT No.50,
BIG-PLUS NO.50,
HSK-A100
BT40,
CAT No.40,
BIG-PLUS NO.40,
HSK-A63
  • *Option
The symmetrical spindle unit design minimises spindle displacement due to heat generation during machine operation.
Reduces program creation time
3D ASSIST
Create programs directly from 3D CAD data
QUICK EIA
Visualisation of G code(EIA) programs
By visualising the G code(EIA) program, it supports checking and editing of small program increments. Visible search on touch screen can reduce the time for program checking.
Distance between columns: 860 mm
Distance between columns: 1500 mm
Distance between columns: 2500 mm
