Die and Mould
Moulds are used in a variety of products, including body components for automobiles, automotive interior parts, computers, home appliances, PET bottles for beverages, and everyday goods. The production of moulds requires high-level metalworking skills to achieve high precision finishes on various materials such as alloy tool steel, ductile cast iron, and resin. Mazak proposes 5-axis machines and multi-tasking machines with optimal machine performance for mould processing and adaptation to the latest materials. These machines contribute to cost reduction by achieving high-productivity and process consolidation, thereby reducing lead times. In recent years, there has been an increase in the demand for machining complex-shaped, ultra-precision moulds made from diverse materials. We also provide solutions that include processing techniques to achieve rapid and excellent surface roughness finishes.
Examples of machining by Mazak 5-axis, multi-tasking machines, and machining centres
Beverage spout mould
Reflector
Rubber product mould
Mould for general industrial machinery parts
Mould for automotive parts
Mould for general industrial machinery parts by a combination of 3 to 5 axis machining
Mouse mould by 5-axis machining
Mirror-finished bevel gear mould to reduce polishing process
Electric motor spindle for high-precision finishing
The electric motor spindle enables high-precision finishing with small-diameter tools required for die/mould machining. By attaching a compact electric motor spindle with automatic tool changer (ATC) capability to the standard spindle, high-quality mirror surface machining can be achieved.
Max. spindle speed: 60000 min-1 / 80000 min-1
Reflector (mirror-finished)
Size35 mm × 31.5 mm × 20 mm
Workpiece materialSTAVAX (52HRC)
ToolsΦ2 mm ball end mill
Spindle speed60000 min-1
Surface roughnessRa 0.05 μm
(average of measurements at 3 locations)
Processing time7 hours 38 minutes
Advantages of 5-axis machining
5-axis machining centres allow for continuous multi-face machining, enabling process integration and reducing production lead times while minimising setup errors due to tool changes. Shortening the tool protrusion length enables stable and high-precision machining under optimal conditions. The inclination of the workpiece allows for faster tool path velocity, ensuring stable surface precision.
3-axis machining centres
Limitations of 3-axis machine tools:
Limitations of machining conditions due to tool projection
Decreased surface precision in machining due to zero tool path velocity
UD-400/5X
Advantages of 5-axis machine tools:
Stable machining of deep steps with short tools
Improvement in surface precision by machining at optimal cutting speeds
Mould repair by wire-arc AM
By incorporating wire-arc metal additive moulding capabilities into a simultaneous 5-axis machining centre, it becomes possible to streamline the mould repair process and automate the expertise required for skilled mould repair. This enables a one-setup process from cutting to remove the damaged part in need of repair, to metal deposition (AM) processing, and finishing cutting of the layered part.
Process integration of the repair process; one machine, one set-up
Mazak machine tools used for precision mould manufacturing
High-efficiency die and mould machining by multi-tasking and 5-axis machining centres
INTEGREX i-H Series
Simultaneous 5-axis Horizontal Multi-Tasking Machine
From turning to 5-axis machining using the Y-axis and B-axis, this machine can handle multiple processes
VARIAXIS i NEO Series
Simultaneous 5-axis Vertical Machining Centre
The high-performance NEO series with high-productivity and low environmental impact technologies
UD-400/5X
High accuracy 5-axis machining centre for mould and precision machining
Designed for high-speed micro precision and mould machining
Highly rigid, high-precision vertical machining centre series
FJV Series (BT40)
High-accuracy BT40 double column machining centres
Double column construction designed for high-accuracy machining over extended periods of operation
VCN Series
High-performance Vertical Machining Centres
Compact, high-rigidity, high-power spindle motor improves productivity
Enquiries about our products
