Automation Systems for Turning Centres
A full line-up of automated systems to suit production volume and product type
For Turning Centres
Machining centre Turning centre Workpiece transport type
Compact automation system with collaborative robots
  • Includes a robot arm, a vision sensor and dedicated software
  • Compatible with Mazak’s small and medium-sized multi-tasking machine, CNC turning centres and vertical machining centres
  •  Utilising collaborative robots to create a safe and compact system
Ez LOADER 10
Maximum workpiece weight : 5 kg
Ez LOADER 20
Ez LOADER 30
*Single-handed
Case study
Ez LOADER 20 + measuring unit
Ez LOADER APP*
*Only compatible with Ez LOADER 30
Smooth TURN ASSIST
Easy operation by just entering the material and the shape of the finished product.
Even if you do not have expertise in robot operation, you can intuitively and easily set up with the system software (Smooth TURN ASSIST) built into the CNC. From the material, outside diameter of the finished product, length and amount input to Smooth TURN ASSIST, installation instructions for the positioning guide bar of the stocker unit and the instructions for installing jaws for the robot arm are displayed on the screen. In addition, the height position of the material is set automatically.
Gantry Loader
Simple system design enables high-speed, high-precision workpiece replacement
Includes a working hand and work conveyor. Teaching-less design for easy set-up and high productivity.
MULTIPLEX W-200Y + Gantry Loader
INTEGREX i-200H ST + Gantry Loader
Two-unit connection
Multiple machines can be connected with a single gantry loader. Depending on the target workpiece, it is also possible to incorporate and arrange material conveyors, finished product conveyors, reversing tables, measuring units, etc. between each process. This system is often used in mass production.
Smooth RCC (Robot Cell Controller)
Software for autonomous operation and management of robot cells
Smooth RCC (Robot Cell Controller) is software for automatic operation and management of robot cells. It enables high-mix, low-volume production using robot cells. You can create operation data of the robot cell, check the schedule progress and operation status. In addition, the shortage of tools and tools that have reached the end of their life are displayed before operation, so that machine stoppages can be prevented during unmanned operation.
Resource Check
Prevent shortages of programs and tools and eliminate automatic operation stoppages
Smooth RCC prompts preparation by displaying programs and tools that are missing due to resource checks against the machining schedule entered before machining. During automated operation, real-time tool simulation is performed to display missing and life-saving tools, and to inform you of tools that need to be prepared.
Robot Setup Assist
Easy robot setup
By inputting the length and diameter of the material and the information of the robot hand on MAZATROL SmoothAi, it is an interactive feature that can effortlessly generate an operation program automatically, eliminating the need for manual machine teaching. Robot Setup Assist is an optional feature of MAZATROL SmoothAi.
Bar feeder
Enquiries about our products
