Minokamo Plant 1
Minokamo Plant 1 is the largest production facility in our company, where the INTEGREX multi-tasking machine series, CNC turning centres, compact vertical machining centres and laser processing machines are produced.
Fully networked with Minokamo Plant 2, this is a facility that specialises in machining with high-efficiency automation, where production is optimised to meet a wide range of customers' production requirements.
This facility has advanced production equipment, such as FMS lines with 5-face machining centres for large workpieces, equipment used to produce ball screw components and a clean assembly area which is required for laser processing machines.
Post code505-0005
Address333 Yamazaki, Naka-Hachiya, Hachiya-cho, Minokamo City, Gifu-Pref.
TEL+(81)0574-25-8311
FAX+(81)0574-28-2145
Access
By Car
  • About 30 minutes from the World Headquarters
  • From Chubu Centrair International Airport
    Centrair Higashi interchange... Chita Peninsula Road... Isewangan Expressway... Tokai-Kanjo Expressway... Minokamo interchange
    About 1 hour 40 minutes
  • About 10 minutes from the Minokamo interchange
By Train
  • About 8 minutes by car from JR Mino-Ota Station
  • About 30 minutes by car from Meitetsu Inuyama Station
Facilities
Yamazaki Mazak Optonics Corporation
505-0005
TEL:+(81)0574-28-2123
FAX: +(81)0574-28-1937 (Sales/Production) +(81)0574-28-1936 (Engineering)
World Technology Centre
The World Technology Centre is the showcase site for our Technology Centres around the world. The latest models are regularly updated, and more than 20 units are always on display.
We display a number of applications machined by Mazak machines with advanced technology, and offer total solutions, including advice on parts machining and productivity improvement.
Minokamo Mega Solar
Solar power generation system covering an area of 3,200 m2 (344,444 ft2) is in operation on the Minokamo plant 1 property. In the event of a disaster, the facility will also contribute to the local community as a facility capable of supplying electricity to Minokamo City.
