Free trial versions of the production support software are stored in the "Mazak Software" folder in the "Application Manager" of the CNC controls MAZATROL SmoothAi and MAZATROL SmoothG (Windows 10). You can install each software on your computer and try it out before making a purchase.
Installation procedures, operating environment, and operation instructions required for each software are also attached in PDF format.
Smooth OMM and Smooth Set and Inspect come with pre-installed software that can be called up from the "Application Manager" and used immediately.
Production Support Software | summary |
Smooth Monitor AX | Machine operation monitoring and analysis |
Smooth Scheduler | Production scheduling |
Smooth Tool Management | Centralize tool data management |
* Smooth Link | View and edit tool data and programs on mobile devices |
Smooth Project Manager | File management, Project data synchronization |
Smooth OMM | On-machine measurement software |
Smooth Set and Inspect | On-machine measurement software |
* Smooth Link is ready to use immediately by connecting to your Wi-Fi as the software is pre-installed.
Smooth PMC NEO and Smooth MPP come with a free trial version of the aforementioned Smooth Monitor AX and Smooth Link software.
