Tool shank | CAT No.40 |
Max. spindle speed | 12000min-1 (rpm) |
Table size | 950 mm × 360 mm |
Ez Operation
15-inch touch screen for intuitive operation
A screen designed for ease of use, with a display that can be customized.
Ez Machining
Equipped with heat displacement compensation system "Thermal Shield"
SMC (SMOOTH MACHINING CONFIGURATION) can adjust machining features according to the processing shape and method.
Ez Setup
Flexible layout
You can customize the layout of the CNC screen, including the displayed data, menus, and on-screen keyboard.
Moving the keyboard to a position that suits the desired height reduces the load on the operator.
Customizable display
You can display any combination of information. By customizing a unique combination according to your work process, you can check the data and work with minimal screen transitions.
