CNC Turning Centers
QUICK TURN
Evolving best-selling high-performance CNC turning centers
  • Built-in motor spindle and high-rigidity machine construction to provide unsurpassed performance
  • Turning, milling, Y-axis, and second spindle specifications designed to meet your production requirements
  • Wide range of chuck sizes and center distance for small and large machining tasks
QUICK TURN image
Built-in motor spindle, which is equipped on all models of series can perform heavy duty machining of difficult machining materials or ferrous metals, as well as high speed machining of non-ferrous materials such as aluminum. You can select the optimal spindle, including high speed and high torque specifications to meet your machining requirements.
Continuous machining of the first and second processes with a second spindle
The second spindle can perform high-speed and high-quality turning and milling with its built-in motor spindle. C-axis indexing in 0.0001° minimum increments is standard. Contouring is optionally available.
NC tailstock and steady rest
The operator can move the NC tailstock to the correct position and set the optimal thrust force, supporting high-accuracy machining of shaft workpieces. Together, NC tailstock and steady rest effectively suppress and maintain stability of long and small diameter workpieces and large-diameter workpieces machining.
NC tailstock
Steady rest
High rigidity construction
Machine construction and CNC technology provide even more stable machining accuracy
The rigid machine construction is designed to ensure high precision during heavy-duty machining and high-speed feedrates.
Without gear belt, built-in motor spindle minimizes vibration and improves roundness and machined surface accuracy.
Roller guides with excellent speed and durability are used on all axes.
High speed drum turret with minimum interface
Depending on the model, 12 position drum turret, 16 position drum turret and 12 position drum turret (24 position) can be selected. Drum turret with minimum interface and non-lift rotary indexing perform high-speed clamping/unclamping. Tool holder can be selected between bolt-on or VDI.
Bolt-on turret
VDI turret
High precision, high speed spindle
An integral motor is utilized for the turret milling spindle to minimize vibration for high accuracy. The motor unit is cooled to minimize heat generated during high-speed revolution.
A variety of optional automation equipment to increase productivity
Ez LOADER is a space-saving automation system with collaborative robots. With the specialized software, Ez LOADER eliminates tedious robot teaching tasks and can be easily set up by anyone.
The touch panel is intuitive, and the 3D model display allows you to create programs while checking the machining shape and process. It prevents program errors and shortens program creation time. G code programming is also available.
SOLID MAZATROL (Automatic / Conversational Programming)
MAZATROL programs are automatically generated from 3D models created with commercially available CAD/CAM software. Optimal programs are generated by learning the appropriate machining pattern for the machining shape from programs created in the past.
Chuck size: 6-inch
Chuck size: 8-inch
  • Bolt-on
QUICK TURN 200
Chuck size8″
Max. machining diameterΦ350 mm
Max. Machining Length511 mm
  • Milling
  • VDI
QUICK TURN 200M
Chuck size8″
Max. machining diameterΦ380 mm
Max. Machining Length538 mm
  • Milling
  • Y-axis
  • VDI
QUICK TURN 200MY
Chuck size8″
Max. Machining DiameterΦ380 mm
Max. Machining Length541 mm
  • Milling
  • Second Spindle
  • VDI
QUICK TURN 200MS
Chuck size8″
Max. Machining Length575 mm
  • Milling
  • Second Spindle
  • Y-axis
  • VDI
QUICK TURN 200MSY
Chuck size8″
Chuck size: 10-inch
Spindle 18.5 kW (25 HP)
  • Bolt-on
QUICK TURN 250
Chuck size10″
Max. Machining Length475 mm / 995 mm
  • Milling
  • VDI
QUICK TURN 250M
Chuck size10″
Max. Machining DiameterΦ360 mm
Max. Machining Length504 mm
  • Milling
  • Y-axis
  • VDI
QUICK TURN 250MY
Chuck size10″
Max. Machining Length1024 mm / 924 mm
  • Milling
  • Second Spindle
  • VDI
QUICK TURN 250MS
Chuck size10″
  • Milling
  • Second Spindle
  • Y-axis
  • VDI
QUICK TURN 250MSY
Chuck size10″
Max. Machining Length541 mm / 924 mm
Chuck size: 12-inch
Spindle 30 kW (40 HP)
  • Bolt-on
QUICK TURN 350
Chuck size12"
Max. Machining DiameterΦ420 mm
Max. Machining Length603 mm / 1538 mm
  • Milling
  • VDI
QUICK TURN 350M
Chuck size12"
  • Milling
  • Y-axis
  • VDI
QUICK TURN 350MY
Chuck size12"
Max. Machining Length603 mm / 1538 mm / 2053 mm
  • Milling
  • Y-axis
  • VDI
QUICK TURN 350MY
Chuck size12"
Max. Machining Length629.8 mm / 1224.8 mm / 1564.8 mm / 2079.8 mm
  • Milling
  • Y-axis
  • Second Spindle
  • VDI
QUICK TURN 350MSY
Chuck size12"
Chuck size: 18 / 21 inch
Spindle 37 kW (50 HP)
  • Bolt-on
QUICK TURN 450M
Chuck size18"
Max. Machining DiameterΦ580 mm
  • Milling
  • VDI
QUICK TURN 450M
Chuck size18"
  • Milling
  • Y-axis
  • VDI
QUICK TURN 450MY
Chuck size18"
