Chuck size | 15" to 21" |
Max. machining diameter | Φ820 mm |
Y-axis travel | 500 mm |
INTEGREX e-H
- Large swing and Y-axis stroke for large workpieces
- Wide variety of optional equipment for process integration and enhanced versatility
Combining years of trust and technical expertise
Orthogonal design provides large operation area and high-accuracy machining
Powerful milling performance equivalent to that of machining centers. Highly rigid structure and wide variety of features for high-accuracy
Enhanced productivity through process integration
Reducing processes by one-eighth and lead times by one-fifth
The INTEGREX e-H series completes the entire process from raw material input to final machining with just one machine. Many benefits can be expected, including a significant reduction in production lead time, high accuracy due to fewer setup processes, cost savings in terms of fixtures and equipment, reduced machine installation space, and energy efficiency.
Powerful milling spindle for faster cycle times
Built-in motor spindle
A built-in motor spindle is adopted. Vibration is minimized during high acceleration/deceleration to ensure exceptional roundness and surface roughness.
Spindle temperature control
Temperature-controlled cooling oil is circulated around the spindle bearings and headstock to minimize thermal displacement of the spindle due to heat generation allowing high machining accuracy to be maintained.
Large machining area
The milling spindle with an automatic tool changer has minimum tool interference. The same tool can be used vertically, horizontally, and at any angle, enabling a variety of machining operations with fewer tools. It has a large range of motion to accommodate all types of machining.
Process integration and expansion of machining performance
Long boring bar system
Effective for the deep machining of inner diameters of large workpieces
- Max. tool length: 1000 mm, 1500 mm (6000 U/8000 U)*
- Tools can be stored in the dedicated stocker
e-500H: 2 pcs, e-670H:3 pcs, e-800H:4 pcs - Tool head can be changed automatically
- *| ATC max. length: 1000 mm (e-670H, e-800H)
CNC system MAZATROL SmoothAi
