Table size | 1740 mm × 750 mm |
Vertical Machining Centers
FJV (CAT No.50)
- Highly rigidity double column construction for high-accuracy machining
- High-accuracy built-in motor spindle/motors for high-efficiency machining
- Designed for high-efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
- 1: The double column construction delivers high-accuracy machining over extended periods of operation
- 2: High-accuracy positioning by ball screw and direct servo mounting
- 3: Spindle temperature control prevents changes in machining accuracy
- 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Temperature controlled cooling oil circulates through the ball screw cores. It ensures stable machining accuracy over extended periods of high-speed operation.
High-accuracy integral spindle/motors for high-efficiency machining
Equipped with a integral spindle/motor, it eliminates the need for driving gear. It can reduce power loss and minimize vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High torque spindle and high speed spindle (CAT No.40) are available as options
A 10000 min -1 standard spindle that can handle machining of various materials such as cast iron, steel, and nonferrous metal , a 7000 min -1 high-torque spindle (optional) that is effective for rough machining of steel and cast iron, and a BT40 18000 min -1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high-speed machining are available.
Standard spindle | High torque spindle* | High speed spindle(BT40)* | ||
Cont. rating | 30 kW (40 HP) | 22 kW (30 HP) | 26 kW (35 HP) | |
Cont. rating | 239 N・m | 318 N・m | 57 N・m | |
Tool shank | CAT No.50, | CAT No.50, | CAT No.40, |
- *Optional
More options to integrate process and achieve high productivity
Multi-surface machining attachment (optional) enables four face machining with one angle tool
An additional axis (optional) that enables control of the 4th axis by commands in the machining program
2-pallet changer (optional) to load the next workpiece during the machining of the current workpiece
3D ASSIST
QUICK EIA
