Vertical Machining Centers
FJV (CAT No.40)
High-accuracy BT40 double column machining centers
  • Double column construction designed for high accuracy machining over extended periods of operation
  • BT40 high-rigidity spindle for the latest cutting technologies, from heavy cutting to high-speed machining
  • CNC system can be selected from MAZATROL SmoothG and MAZATROL SmoothC
Panoramic view of FJV-250
FJV BT40 processing scene
  • 1: |The double column construction delivers high accuracy machining over extended periods of operation
  • 2: |High-accuracy positioning by ball screw and direct servo mounting
  • 3: |Spindle temperature control prevents changes in machining accuracy
  • 4: |Linear roller guides for high rigidity are used on all axes
FJV BT40 machine structure
Ball screw core cooling
Symmetrical headstock design
The symmetrical headstock design together with the integral spindle / motor minimizes spindle displacement due to heat generated by the spindle operation.
* Available with the MAZATROL SmoothG.
High-accuracy built-in motor spindle for high-efficiency machining
From nonferrous metals to high-hardness materials, the machine provides high-efficiency machining for a variety of applications in the semiconductor, electronics, aircraft, and mold industries.
Spindle variation from high torque to high-speed machining
  • 12000 min-1 standard spindle for a wide range of applications from nonferrous metal to steel cutting
  • 12000 min-1 high-torque spindle (option) for heavy-duty, rough machining of steel and cast iron
  • 18000 min-1 high-speed spindle (option) for machining of aluminum, copper, and other similar materials
  • 25000 min-1 high-speed spindle (option) for high speed die machining with small diameter end mills.
FJV BT40 spindle
FJV BT40 quartz sample work Quartz: Sample workpiece
FJV BT40 aluminum aerospace bracket Aluminum: Aerospace bracket
FJV BT40 prehardened steel mold for automobile component Prehardened steel: Mold for automobile component
Profiler Machining Package (optional)
For machining that requires high contour control, the machine's performance is maximized. Contour accuracy is improved even with high feedrate, so there is no need to reduce the feedrate or acceleration/deceleration, which leads to shorter machining times. It is highly effective for high-speed, high-precision machining of scroll-shaped parts and machining that requires pin angles for metal mold design surfaces.
*Optional coolant temperature control system(water-soluble) and scale feedback(X-, Y-, Z-axis) are required.
Profiler Machining Package Exclusive Smooth Machining Configuration Setting Screen
common_mazatrol_smoothg
Unsurpassed ease of operation with touch screen A wide range of applications supports from setup to machining.
common_mazatrol_smoothc
MAZATROL SmoothC
Simplified display and key input operation
FJV series (CAT No.40)
