Table size | 1740 mm × 750 mm |
Vertical Machining Centers
FJV 5 Face
- Units and functions that make 5-surface machining accessible as standard equipment, achieving process integration
- Highly-rigidity double column construction for high-accuracy machining
- High-accuracy built-in motor spindle for high-efficiency machining
- Designed for high-efficiency in machining large workpieces, with a wide lineup that can handle long shaft workpieces
Units and functions that make 5-Face machining accessible as standard equipment
Four side face machining with one angle tool
The MAZAK 5 Face angle head is capable of powerful cutting with its unique hydraulic pressure clamping unit that provides strong fixation.
Wide angle head cutting range
Compact angle head reduces interference with workpiece for large machining area.
Enhanced versatility
The dedicated angle tool magazine has a storage capacity of 8 tools, which makes it possible to handle a wide variety of workpieces.
Simplified programming
The MAZATROL conversational program for 5-surface machining makes it easy to create programs for side face machining.
- 1: The double column construction delivers high-accuracy machining over extended periods of operation
- 2: High-accuracy positioning by ball screw and direct servo mounting
- 3: Spindle temperature control prevents changes in machining accuracy
- 4: Linear roller guides for high-rigidity are used on all axes
Ball screw core cooling
Equipped with a built-in spindle, it eliminates the need for driving gear. It can reduce power loss and minimize vibration during high-speed operation to ensure exceptional surface finishes and maximum tool life.
High torque spindle and high-speed spindle (CAT No.40) are available as options
A 10000 min -1 standard spindle that can handle the machining of various materials such as cast iron, steel, and nonferrous metal , a 7000 min -1 high torque spindle (optional) that is effective for rough machining of steel and cast iron , and a BT40 18000 min -1 high-speed spindle (optional) that enables highly efficient machining of nonferrous metal and difficult machining material through high-speed machining are available.
Standard spindle | High torque spindle | High speed spindle(CAT No.40) | ||
(Cont. rating) | 30 kW (40 HP) | 22 kW (30 HP) | 26 kW (35 HP) | |
(Cont. rating) | 239 N・m | 318 N・m | 57 N・m | |
Tool shank | CAT No.50, | CAT No.50*, | CAT No.40*, |
- * Optional
3D ASSIST
QUICK EIA
